Old 11-11-2018   #1
Jim Stanley
Default Compression testing
What do I need to do besides remove all the plugs in preparing for compression test? Pull fuel pump fuse? Disable coils???
Thanks!
Sent from my iPad using ZR-1 Net Registry
Jim Stanley is offline   Reply With Quote
Old 11-11-2018   #2
Default Re: Compression testing
What works for me...
  • Make sure the batter is fully charged. Note the voltage (fully charged it should read 12.4-12.6 with no load).
  • Connect a battery charger so the battery can fully recover between tests
  • Check oil level and top it off if needed. (Note the voltage when fully charged)
  • Start motor and monitor oil pressure comes up to normal for (30 sec or so) before shutting motor off
  • Pull the plugs
  • FLOOR the accelerator (signals the ECM for "clearing flooded engine)
  • With trans in neutral (and the clutch depressed too) and the pressure gauge connector/tube inserted into the first cylinder spark plug hole, engage the starter while watching the pressure gauge. Let the starter spin until the gauge reading "peaks".
  • Record the cylinder number and the pressure attained
  • Repeat for each cylinder until all have been tested.
Old 11-11-2018   #3
Jim Stanley
  • Pull the plugs
Thank you for the detailed procedure, Paul.
When you say "FLOOR the accelerator", Do you mean once or throughout the individual cylinders?
Much appreciated!
Old 11-11-2018   #4
Much appreciated!
Hold it open during the compression test of each cylinder
