![]() Join Date: May 2012
I got a Smokin deal on a set of (8) 24# Accel fuel injectors, will these work as secondaries on a stock engine without retuning? Plug n play like the 21#s?
Anyone.....
![]() Join Date: Mar 2007
No they will run way too rich...
You will likely get a rich code.
The calibration needs to be modified to tell the ECM it has bigger injectors. That might be enough but likely it won’t be. U will at least need to run a before and after datalog to confirm. The Injector Bias will also need to be updated to the correct values. Otherwise who knows.
Finally, I’m not a proponent of mixed injectors. Use one or the other. The calibration doesn’t differentiate between 2 different value injectors. Its looking for one type injector, and will treat the other one as if.... |
#9 | |
#10 |
I love Pete. He is a great, great friend. Doesn’t mean I agree w everything he does. And he and I have discussed this. You can “make it work” but I’d rather not.
