Old 11-02-2018   #1
Jim Stanley
Default Fuel filter change issues
After replacing my injectors and before starting the car, I thought it would be an opportune time to change the fuel filter. After removing the fuel line on the input side it leaked over two cups at a dribble rate. It slowed a bit but never got to the drip-drip stage. I got concerned about the fumes, etc. and put the line back on pending thoughts from the forum. Its not worth going up in flames!
Note: The fuel rails are empty, the gas cap has been burped, and the car hasn't ran or had the battery hooked up for a month. The fuel tank is about half.
How long does it take to quit dripping, or does it?
Thanks for any helpful comments/suggestions.
If this is too basic of a question for you please disregard.
Jim Stanley is offline   Reply With Quote
Old 11-02-2018   #2
Demps
Demps's Avatar
Default Re: Fuel filter change issues
If everything you said & you leave the gas cap off...a large mason jar.
Ted
Old 11-03-2018   #3
ZWILD1
ZWILD1's Avatar
Last time I changed one in my previous car I did the following. I placed a clean oil change pan under the fuel filter. Next I had several vacuum plugs handy that you can buy at any auto parts store. I used one to block off the line until ready to install the new filter. But you are going to loose a bit of gas no matter what. The worst part was fuel running down my forearm.
91 Turquoise Metallic Haibeck 525 #0134
ZWILD1 is offline   Reply With Quote
Old 11-03-2018   #4
Flyman 27
Flyman 27's Avatar
Same here. You just have to change the filter quickly so you lose the least amount of gas possible. Mine wouldn't stop dripping until I slipped the new one into place.
91-#1935 Black/black & gray, Haibeck 500
Cams by Pete
Flyman 27 is offline   Reply With Quote
Old 11-03-2018   #5
........... The worst part was fuel running down my forearm.
At least it was just your forearm. I was under a lift & gas ran all the way down my arm to my armpit. Doesn't have to be flaming to burn like hell! I won't do that again......EVER!
Old 11-03-2018   #6
Karl
Karl's Avatar
When I changed mine I disconnected the three fuel lines at the gas tank to relieve pressure.
Fuel dripped for a few seconds and it then it stopped all together. You will loose a small drip or two at the real lines also. Most of the fuel in the line from the tank to the filter will come out.
1993 ZR-1 #211 Yellow On Beige Beast #2
1992 ZR-1 #427 Black On Black *Sold*
1985 L98 Blue On Blue *Sold*
Old 11-03-2018   #7
Jim Stanley
Thanks for your comments. I will plug the line and work fast.
Sent from my iPad using ZR-1 Net Registry
