Old 10-17-2018   #1
zr1assassin
zr1assassin's Avatar
Default Aluminum flywheel.... new clutch?
Thinking about swapping out to an aluminum flywheel, do you have to or need to get a new clutch when swapping flywheel? Car a 92' has 20k miles so I'm assuming clutch wear is minimal.
Looking at a fidanza 198551
zr1assassin is offline   Reply With Quote
Old 10-17-2018   #2
Default Re: Aluminum flywheel.... new clutch?
FYI: converting from a dual mass flywheel will result in transmission rattle which is loudest when in neutral with clutch engaged.
The Fidanza FW weighs in at 13-14 lbs
Jerrys Gaskets has custom manufactured aluminum FW’s at both 18 & 22 lbs. read more about applications & benefits;
http://www.jerrysgaskets.com/flywhee...let-90-95-0b3/
http://www.jerrysgaskets.com/flywhee...let-90-95-0b1/
Old 10-17-2018   #3
Vette73
My fidanza sounds like a sawz-all at times up until 2,500 RPM......All though the motor will spin up much faster .....The gear rattle in neutral really doesn't bother me......I hear some have used a sprung hub disc to mitigate the noise.....
No,stock clutch can be used....I did and I was at 46 k...
Vette73 is offline   Reply With Quote
Old 10-17-2018   #4
zr1assassin
Just swapped out flywheel and that's it?
Old 10-17-2018   #5
Demps
Demps's Avatar
I have Fidanzas in three cars. I'd follow Jerry's suggestions.
If you choose Fidanza, I would replace the clutch disk and make sure it's a spring hub and minimum thickness. Be sure to clean the frictions surface on the flywheel.
Ted
Demps is online now   Reply With Quote
Old 10-17-2018   #6
zr1assassin
Ted
Recommendations on a disc/sprung hub?
Old 10-17-2018   #7
efnfast
I think I have a Fidanza for sale. I might have sold it.
Old 10-17-2018   #8
zr1assassin
I just ordered one 20min ago lol
Old 10-17-2018   #9
Vette73
I hear part # 381039 from summit racing is a good choice...
Old 10-17-2018   #10
zr1assassin
Awesome thank you
