10-13-2018 | #1 |
ZOOMIES FOR '95
Have a '95 all stock except for Haibeck chip & want give it some extra "growl" without replacing the entire exhaust system.
Thinking of zoomies, ala Kindig-it $425. I know install s/b after O2 sensor, but what about cats. I believe O2 is before cat. Any suggestions to brands? hp impact? Car has already Top Flighted w very hi score, so not concerned on that issue. Thx |
10-13-2018 | #2 |
Re: ZOOMIES FOR '95
There's only a couple of places they would fit before the mufflers, and even fewer places before the resonator. Plus they'd hang down somewhat, and our cars are already low to the ground. If you think speed bumps and driveways are a PITA now.......
To make them fit up tight to the body you'd probably have to monkey around with the floor pans of the body and that wouldn't be cheap or easy. Just my $0.02 'Crabs
10-14-2018 | #3 |
Re: ZOOMIES FOR '95
Thx crabs. I'll take another look but I thought they
Might mount higher up if before the cats. If after cats Yeah, can't go any lower than pipe already is. |
