10-12-2018 | #1 |
Thermostat Housing Fun
Not an unfamiliar issue, but always fun. If I was more content with my heater not working, I would have left it alone.
I'm stopping by a machine shop tomorrow to see if I can drill and tap. A #6 extractor was no help today. Anybody have success stories fixing this?
1993 Bright Aqua Metallic # 027 |
10-12-2018 | #2 |
Re: Thermostat Housing Fun
Both metals (aluminum t-stat housing & pot metal connector) are soft, so extra care needs to be taken to not damage the threads. EZ-outs frequently make removal more difficult because they expand the broken part, aka "dutchman," making it tighter. Drilling to remove is OK for straight threads, but the thread form used in this application is a tapered pipe thread. If done carefully, you can use a small chisel to drive one side of the dutchman towards the center, effectively collapsing it inward. The dutchman, being fragile is a benefit to this method. Once one side is collapsed& removed, the remainder is easy to remove using the same method at a different location. When completed, chase the threads with the proper tap size, being careful to not run it too deep. Again, this is a tapered thread (NPT), removing too much metal can be detrimental to tightening the new connector.
Taking the t-stat housing to a machine shop is a good idea, they will have all the necessary skills & tools. Screwing up the t-stat housing can make the repair more costly.
10-12-2018 | #3 |
Get a hold of this company: JERRY'S BROKEN DRILL AND TAP REMOVAL. Santa Ana, Orange County. I have used him for car parts. The aerospace industry uses him for their stuff. Reasonable costs. Small outfit. Nice man.
George |
10-12-2018 | #4 |
Thank you Jerry for the great advice; I was on the phone with you a couple days ago about this. I have not found a replacement housing anywhere, so being ginger with this one is the biggest priority.
I'll look into the Broken Drill and Tap Removal Business
10-13-2018 | #5 |
Is this the guy that uses ultrasonic something the dissolve the broken part? I read a story in HOTROD Magazine years ago about a shop in L.A. that did this type of work.
10-13-2018 | #6 |
He has a lot of tools at his disposal. One "etches" away at the steel. One of the things he did for me was remove a #8 steel screw from a painted aluminum part. He made no promises
to no damage the paint and yet he did not damage the paint. As for being in a rag, IDK George |
10-13-2018 | #7 |
Machine shop would be good idea. A really good TIG welder can lay in some new metal and the machine shop can recut the threads. Would be interested to hear about the broken drill and tap guy for sure!
Sent from my XT1585 using ZR-1 Net Registry mobile app |
