Old 10-05-2018   #1
Vette73
Smile Fuel pumps fuse location ...91 Z..
Like the title states....Where is the exact locations of the primary and secondary fuel pump fuses.?
Vette73 is offline   Reply With Quote
Old 10-05-2018   #2
jss06c6
Default Re: Fuel pumps fuse location ...91 Z..
Only know of one fuse.. FP1 in lower right of fuse block on the side of the dash, passenger side..
Old 10-05-2018   #3
geezer
2nd is under the passenger side dash. Remove the carpet bolster under the glove box.
Search on here for access procedure as there is a hidden screw accessed by removal of end of dash pass. side fuse panel surround.
geezer is offline   Reply With Quote
Old 10-05-2018   #4
TX '90 ZR1
TX '90 ZR1's Avatar
The information I have is for a '90. The '91 may or not be the same.
Primary pump fuse in in location #24 (10 amp) of the fuse block on the outside end of dash on passenger side. (Open the passenger door, you will see it on the "end" of the dash).
The secondary pump is in position #1 (10 amp) of a 4 position fuse block located under the passenger side dash and towards the firewall. This one is not real easy to see. It is mounted up in there with all the other stuff that is next to impossible to get to.
Kenny
1990 #442
Old 10-05-2018   #5
Vette73
Ok sounds good...Figure I check those first before anything else....
Old 10-05-2018   #6
geezer
The block is located under the passenger hush panel. The panel is held by two screws on the bottom edge, and one screw under the bottom right of the cover for the main fuse panel. (that panel cover is held by 3 screws). Find the AUX FUSE BLOCK located right of center of the hush panel, directly above where a passenger's right ankle might rest. The AUX BLOCK might be obscured by some wire harnesses that might have to be pushed aside to view/access the fuses thereon.
