Old 09-25-2018   #1
aafc
aafc's Avatar
Default 85 mile trip
drove to my buddies house 85 miles, shut car off then tried to restart to move car. Long time cranking, but fired up ran about 15 sec then stopped. Check fuel with good pressure, same thing each time to start car, also check gas for water, no water in gas. any thoughts? John
aafc is offline   Reply With Quote
Old 09-25-2018   #2
QB93Z
QB93Z's Avatar
Default Re: 85 mile trip
Did you notice a high coolant temperature? The symptom of shutting down 15 seconds after start sound like a computer shutdown.
1990 Black ZR-1 - sold
1993 Quasar Blue ZR-1
1994 Competition Yellow ZR-1
1995 Dark Purple ZR-1
Maryland State Coordinator
Old 09-25-2018   #3
aafc
aafc's Avatar
Ok, update coolant temp about 93 c.Turns out the FP1 fuse had blown.Did not have the jumper to switch from pri to sec pump to check. Left it sitting on the work bench. So after a few cool drinks (gator aid ) . We then started the kiss system .You know look at the simple things first. And that's the first we did .Allows carry spare fuses;
Thanks
Old 09-26-2018   #4
QB93Z
QB93Z's Avatar
Glad you got it figured out.
Old 09-26-2018   #5
I wonder where you got that idea?
90 #1202
Sans secondaries
SW headers, X-pipe, MF muffs
Old 09-26-2018   #6
QB93Z
QB93Z's Avatar
I won't tell if you don't.
