Old 09-23-2018   #1
precast1
precast1's Avatar
Default Replacement AC Delco Battery
Does anyone know what the AC Delco part number I need for a 1990 battery that will get the least point deductions for NCRS judging? Also the best place to buy one.
Thanks for any help.
Sent from my SM-G950U using ZR-1 Net Registry mobile app
precast1 is offline   Reply With Quote
Old 09-23-2018   #2
DRM500RUBYZR-1
DRM500RUBYZR-1's Avatar
Default Re: Replacement AC Delco Battery
https://parts-catalog.acdelco.com/ca...log_search.php
Battery
Part Number: 75VPG
Product Notes:
Gold Battery
All; BCI 75, minimum vehicle Reqment: CCA 690/RC 95
Per Vehicle: 1; Years: 1990-1995
REMOVE THE CARRY STRAP!!!
This one has only the side terminals, so closest to original, although you could also use the dual terminal version, this looks more appropriate.
Marty
Old 09-23-2018   #3
precast1
precast1's Avatar
Thank you Marty I appreciate your help. By chance do you know where I can get an extra set of original keys cut. The knock outs are still in the set I am using.
