Old 09-20-2018   #1
Route 66
Route 66's Avatar
Default Need TCS Nuts
I would like to buy a set of OEM TC shield Nuts if any one has a set they do not want or need. Mine were lost at the GM dealership a long time ago. If you have a set of OEM would you let me know...Thanks..
Route 66 is offline   Reply With Quote
Old 09-20-2018   #2
Default Re: Need TCS Nuts
Try these sources in order:
  1. ACE HARDWARE, Menards, Home Depot
  2. Fastenal (but you'll need the metric thread size and pitch when placing the order)
  3. McMaster-Carr (same deal - need the metric thread size/pitch)
And, while your at it, you can get some stainless hex cap screws to replace better match the new paint on the plenum, etc. (either #2 or 3 will have them for sure. #1 too, except I'm not as sure about that source for those particular cap screws (stainless to boot)).
Old 09-20-2018   #3
Or, you can save yourself the time & expense & just get them here, for delivery to your door! They are identical to OE.
http://www.jerrysgaskets.com/nut-thr...ew-90-95-6-5a/
Old 09-20-2018   #4
efnfast
Well, that sounds like a no brainer.
Old 09-20-2018   #5
Demps
Demps's Avatar
Yep...and a few gaskets for spares in the shipment.
Ted
