Old 08-22-2018   #1
Default DIS Connectors
Does anyone make the connectors for the DIS? I am actually looking for the Ignition module side (So I cam connect them to to my harness..
specifically looking for the back 2, the crank sensor and the main connector
Old 08-26-2018   #2
tpepmeie
Default Re: DIS Connectors
The crank sensor connector is readily available. Metripack. The longer 8-pin (?) flat connector I have never been able to find.
Old 08-26-2018   #3
Thanks Todd I found the mate to that crank sensor. Figured the other would be a hard find
