Old 08-16-2018   #1
KJL
Default My Brakes Don't Seem Fully Release
My brakes seem to grab a bit even when my foot is not on the pedal. My ebrake is off. If my car is in neutral and not in gear, I can not push it. I don't go through brake pads so it is not much but more than I see with my other cars. I expect some drag but not that much. Any thoughts as to what could be the cause?
1995 ZR1 #159
1992 ZR1 #280
1996 Collectors LT4 (Stock)
572 rwhp
Old 08-16-2018   #2
Default Re: My Brakes Don't Seem Fully Release
Caliper pistons are sticky and need a cleaning is my first guess.
Slides on Caliper are sticky is second guess.
Remove Calipers and give them a good cleaning and a new coat of red paint when you are there
