![]() Join Date: Mar 2018
Where do I get what I need to convert to a short shifter in my 91 ZR-1? Does it get harder to shift due to the shorter leverage?
20180717_213014.jpg Sent from my SM-G955F using ZR-1 Net Registry mobile app
Roy Martin 1994 ZR-1 #112 Admiral Blue/Black Dana 4:10 Aluminum flywheel Corsa exhaust Watson headers Haibeck chip 470 HP/399 RWHP 1991 ZR-1 #400 White/Red (SOLD) Dana 4:10 Powder coated engine Haibeck performance chip Borla exhaust Last edited by Norwegianmopar; 08-16-2018 at 04:21 PM. |
![]() Join Date: Jul 2016
The Hurst unit is available here on the registry in the vendor section. It’s a nice piece. Shift effort is very reasonable, you won’t notice much of an increase. The factory shifter has pretty long throws, you have to bend the elbow quite a bit when pulling it back. I find the Hurst to be “just right” not too short, reasonable effort. The ZF Doc shifter is supposed to be very nice too.
#3 | |
Roy Martin 1994 ZR-1 #112 Admiral Blue/Black Dana 4:10 Aluminum flywheel Corsa exhaust Watson headers Haibeck chip 470 HP/399 RWHP 1991 ZR-1 #400 White/Red (SOLD) Dana 4:10 Powder coated engine Haibeck performance chip Borla exhaust |
![]() Join Date: Nov 2011
I've got the Hurst, short throw, short shaft. Love the feel of it. It's notchy, click, click.
![]() Join Date: Jan 2015
#8 | |
#9 |
Mine does not have the reverse lock out.
The ZF Doc says we can all miss that shift once, but it will be expensive. I figure 6th is kinda hard to miss, you never speed shift to 6th. If there is any doubt in my mind, before I release the clutch, I'll check to make sure. |
#10 | |
