Old 08-14-2018   #1
Route 66
Route 66's Avatar
Default Tech 1 or Tech 2
Looking for members who have knowledge of these scanning tools. If you have used ether of these would you post the pros and cons of them. I do not know much about ether one. I am thinking I should get the Tech 2. From what I have read it can be used on the 92 to 2010 vetts' I am having a problem with a 93 ZR1. Not getting the 405 HP and not throwing a engine DTC code. I have no vacuum leaks so it must be electrical. I repaired a vacuum leak under the plenum and while under there I made sure the actuators were working.
Thanks for your input.
Route 66 is offline   Reply With Quote
Old 08-14-2018   #2
conesare2seconds
Default Re: Tech 1 or Tech 2
Personally, i would use a Tech 2. Btw, a possible mechanical cause of your problem is the throttle body. Marc H found mine did not open fully, even with the pedal to the floor. Had him recondition the TB, problem solved. Apparently, this isn’t uncommon as the cars get older.
Old 08-15-2018   #3
Route 66
Route 66's Avatar
It looks like your in Arkansas and Marc H appears to be in Illinois. Did you take your car to him or did you ship the TB to him?. More about the problem I am having. Some time back I got a Code 22 which is a throttle positioning switch. After clearing the fault it has not returned. Now I get no engine codes. But when I first start the car and the engine is not wormed yet it runs real ruff. Some times when it is given gas before the temp reaches about 170 it might back fire. After it's worm it seems do much better almost perfect. But still no 405.......Thanks
Old 08-15-2018   #4
conesare2seconds
I moved to St. Louis this summer Andy need to update my profile. I shipped the car to Marc because it needed other service, then took Amtrak to Chicago and drove it back. Other members have just shipped the TB to him.
Old 08-15-2018   #5
Hib Halverson
There'd be little advantage to a T2 vs a T1 for working on a ZR1 other than a screen which will display more lines of data.
Some T2s, especially the Chinese knock-offs, may not have the proper software so, if you buy at T2, make sure the software package which comes with it supports OBD as well as OBDII systems.
Hib Halverson
Technical Writer
former owner 95 VIN 0140
current owner 19 VIN 1878
Old 08-15-2018   #6
Route 66
Route 66's Avatar
Thanks I will do that. The one I am looking at is American made. The reason I am thinking of getting the tech 2 It can also be used on my 07.
Thanks again Ellis
Old 08-15-2018   #7
Route 66
Route 66's Avatar
Sounds like fun. Thanks
