Old 08-10-2018   #1
Default Jerrys Gaskets: New 368 Build Kit
Due to lack of availability for OEM original parts, primarily rings, pistons, sleeves & connecting rods (in that order), Jerrys Gaskets has developed a package containing the same components...... only better. The package is as close to being drop-in, as close as we can make it, like the original parts. Additional steps required for installation are final honing of cylinder sleeves to finish size/clearance and re-balancing.
The new package is applicable for a stock rebuild AND/OR a performance enhancement rebuild. Displacement has been increased to a 4.000" bore for 368 cubic inches. All components are match designed. As an added bonus, Jerrys Gaskets will end gap the new piston rings to the proper dimension, with our new Total Seal Precision Power Ring Filer.
For the do-it yourself owner, we have been expanding our LT5 Special Tools inventory. Although the tools are available for purchase, the intended purpose is to make them available for rental on a much lower cost basis. Each rental period is for 30 days, round trip from us to you. Simply organize your schedule & order when you are ready. Availability may be limited by inventory & prior purchase/rental.
http://www.jerrysgaskets.com/368-sle...new-90-95-000/
Old 08-10-2018   #2
scottskill
Default Re: Jerrys Gaskets: New 368 Build Kit
That's fantastic development for the LT5 community. Christmas my come early for somebody!
Sent from my SM-G955U using ZR-1 Net Registry mobile app
scottskill is offline   Reply With Quote
Old 08-10-2018   #3
conesare2seconds
Thanks for developing this kit.
Old 08-11-2018   #4
phrogs
phrogs's Avatar
Jerry are there any tools youre missing?
I have quite a few if you need to make copies.
JOHNNY P
Currently own
Old 08-11-2018   #5
Ccmano
Jerry, Do you have rod and main bearings too?
Ultimately if I don’t sell my long block I may rebuild this way.
H
Old 08-11-2018   #6
Hi Johnny,
Thanks for the offer. I may need to take you up on it.
Old 08-11-2018   #7
H
Hi Hans,
Yes, we have rod & main bearings.
http://www.jerrysgaskets.com/bearing...rod-90-95-1b1/
http://www.jerrysgaskets.com/bearing...n-90-95-17a-e/
