Old 08-02-2018   #1
Norwegianmopar
Norwegianmopar's Avatar
Default New exhaust - what to buy?
Seems our cats are shot now (sparking/knocking sound from the underside when stepping on it and reduced power above 4000 rpm), and the front muffler has been welded, so we are considering a new exhaust system.
What are you guys recommending? Where to buy?
Does installing headers mean the engine needs to be pulled to get them on? (Someone told me so...)
The car is stock with 4:10 gears and Haibeck chip.
All tips and advice are welcomed [emoji106]20180707_122507.jpg20180707_122457.jpg20180707_122413.jpg
Sent from my SM-G955F using ZR-1 Net Registry mobile app
Roy Martin
1994 ZR-1 #112 Admiral Blue/Black
Dana 4:10
Aluminum flywheel
Corsa exhaust
Watson headers
Haibeck chip
470 HP/399 RWHP
1991 ZR-1 #400 White/Red (SOLD)
Dana 4:10
Powder coated engine
Haibeck performance chip
Borla exhaust
Norwegianmopar is offline   Reply With Quote
Old 08-02-2018   #2
dredgeguy
dredgeguy's Avatar
Default Re: New exhaust - what to buy?
Have enjoyed your photos. You cannot go wrong with Stainless Works headers with their high flow cats and a Corsa exhaust. Great sound at idle and when above 3000 RPM everybody knows you came to the party to play. No drone on the highway. Not the least expensive but worth the investment.
Charlie
__________
Dredgeguy
Dana 4:10 gears
Polished LT5 by Haibeck
Old 08-02-2018   #3
yes, Corsa is nice.. But as stated it is really heard at WOT.. if it was not as loud as it is, I will still have it on my car.. I really liked the no drone aspect of it
Old 08-02-2018   #4
Ccmano
If the cats are coming apart internally, do not run the car! Fine bits of the ceramic will be drawn into the cylinders and will eat up the cylinder walls. If you research on this forum you can find much more on the catalyst issue. I believe AB26 has written considerably on this.
And, no the engine does not have to be removed to install headers.
H
Old 08-02-2018   #5
X2 for Corsa
Old 08-02-2018   #6
Norwegianmopar
H
Should there be a warning lamp coming on if it's the cats..? I have no lamps on at all.
Roy Martin
Dana 4:10
Aluminum flywheel
Corsa exhaust
Watson headers
Haibeck chip
470 HP/399 RWHP
Dana 4:10
Borla exhaust
Old 08-02-2018   #7
Ccmano
No warning lamp, your dealing with 1980’s technology. These cars only have one O2 sensor per side and it’s ahead of the cat. It can’t tell if the cat is bad. Later technology put O2’s on either side of the cat and could monitor cat function. But not on our cars.
H
Old 08-02-2018   #8
rush91
It looks as if you have aftermarket mufflers. If that's the case, I'd cut out the resonator and replace it with an X-pipe with the headers...Nothing wrong with the stock 2.75 exhaust tubing.
rush91 is offline   Reply With Quote
Old 08-02-2018   #9
Norwegianmopar
It has Borla exhaust.
Roy Martin
Dana 4:10
Aluminum flywheel
Corsa exhaust
Watson headers
Haibeck chip
470 HP/399 RWHP
Dana 4:10
Borla exhaust
Old 08-02-2018   #10
Ccmano
Here’s one of the threads by AB26 (Jerry Downey) in the subject of cat failure. Note that in the thread it’s confirmed by Mark Hibeck and even Graham Behan one of the original GM/Lotus engineers. It’s one of the reasons the later cat setup was changed on the 93-95 Cars.
http://www.zr1.net/forum/showthread....light=Catalyst
H
