The key copier guy told me there is a chip in my key (VATS) and I need a chipped key to replace
Are the keys specific to the LT5 or will any blank key off eBay work Thank you. |
There is like 14 different resistor chips , most dealers have the reader to get you the correct key , you can get it cut anywhere !
#3 | |
1. Key Codes. Ohms-----------------------------------------------VATS Key Code # 402 ohms pellet----(acceptable range 386-438 ohms)----------1 523 ohms pellet----(acceptable range 520-564 ohms)----------2 681 ohms pellet----(acceptable range 650-728 ohms)----------3 887 ohms pellet----(acceptable range 850-942 ohms)----------4 1130 ohms pellet---(acceptable range 1085-1195 ohms)--------5 1470 ohms pellet---(acceptable range 1411-1549 ohms)--------6 1870 ohms pellet---(acceptable range 1795-1965 ohms)--------7 2370 ohms pellet---(acceptable range 2275-2485 ohms)--------8 3010 ohms pellet---(acceptable range 2890-3150 ohms)--------9 3740 ohms pellet---(acceptable range 3590-3910 ohms)--------10 4750 ohms pellet---(acceptable range 4560-4960 ohms)--------11 6040 ohms pellet---(acceptable range 5798-6302 ohms)--------12 7500 ohms pellet---(acceptable range 7200-7820 ohms)--------13 9530 ohms pellet---(acceptable range 9149-9931 ohms)--------14 11800 ohms pellet--(acceptable range 11328-12292 ohms)------15 Search C4 Corvette VATS on Ebay.
Clickable links ![]() On Iphone Touchable Links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 07-11-2018 at 06:47 PM. |
Thank you, will this key work?
https://www.ebay.com/itm/1990-96-CHE...gAAOSwRQxab3i5 or are there 15 different choices out there? |
#5 | |
![]() Join Date: Aug 2006
Ecklers has VATS keys by code...…..Vats Corvette Keys by Code
Use and Ohm meter and measure the resistance of the black pellet (resistance from one side of key to other across black pellet). 1. Key Codes. Ohms-----------------------------------------------VATS Key Code # 402 ohms pellet----(acceptable range 386-438 ohms)----------1 523 ohms pellet----(acceptable range 520-564 ohms)----------2 681 ohms pellet----(acceptable range 650-728 ohms)----------3 887 ohms pellet----(acceptable range 850-942 ohms)----------4 1130 ohms pellet---(acceptable range 1085-1195 ohms)--------5 1470 ohms pellet---(acceptable range 1411-1549 ohms)--------6 1870 ohms pellet---(acceptable range 1795-1965 ohms)--------7 2370 ohms pellet---(acceptable range 2275-2485 ohms)--------8 3010 ohms pellet---(acceptable range 2890-3150 ohms)--------9 3740 ohms pellet---(acceptable range 3590-3910 ohms)--------10 4750 ohms pellet---(acceptable range 4560-4960 ohms)--------11 6040 ohms pellet---(acceptable range 5798-6302 ohms)--------12 7500 ohms pellet---(acceptable range 7200-7820 ohms)--------13 9530 ohms pellet---(acceptable range 9149-9931 ohms)--------14 11800 ohms pellet--(acceptable range 11328-12292 ohms)------15
Clickable links ![]() On Iphone Touchable Links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 07-11-2018 at 06:57 PM. |
#7 | |
![]() Join Date: Oct 2004
![]() Join Date: Jan 2010
Last year I paid $35 at
the local Chevy stealership for one. Took them 5 minutes to make it. Could be lots worse, $325 and a lot of BS (proof of ownership etc) for a replacement key at the local Teutonic car emporium ☹️ Last edited by Mystic ZR-1; 07-11-2018 at 08:28 PM. |
#9 |
![]() Join Date: Apr 2017
ACE hardware has a chip reader in their key dept. They read my key & sold me spares that work perfectly.
[SIGPIC][/SIGPIC] 91-#1935 Black/black & gray, Haibeck 500 Cams by Pete |
#10 |
Hi all, I tried copying my ignition key about a year ago as I only received one when I bought the car.
I determined resistor value from my old key and ordered a replacement online and got the key cut. Car fired up perfectly and drove it about 20 mins then turned off the car. Came back a few mins later, key in ignition but no start. Seemed to be a VATS issue from what I read so I left the car about 20 mins. Tried with my old key and it started fine. Has this happened to anybody else? I have refused to use the copied key in case this happens again. Joel |
