Old 06-24-2018   #1
Default 92 Gauges intermittent display
I have had battery disconnected while doing work on AC system. After finishing the work, I connected the (-) cable and started the motor. Usually, I will switch the gauges to Coolant Temps, however, what I got was only a switching back and forth to TRIP and ODO. Of course the Trip button is adjacent to gauges. I can play with the Gauges button and get gauge data. Sometimes it will stay, sometimes revert back to Trip/ODO data.
Anyone encounter a similar situation. Don't think its the cluster. Could be button cluster. If so, is it specific to ZR or generic C4?
Old 06-25-2018   #2
Ccmano
Default Re: 92 Gauges intermittent display
I had a bad DIC button cluster when I first got the car last year. Mostly the buttons did nothing. Occasionally they would work if you pressed and wiggled the button while doing so. Replaced the cluster and all is well. Hope that’s all it is for you.
H
Old 06-25-2018   #3
H
I'll bet its a similar issue. Did u replace the DIC with a specific ZR-1 DIC or does any latter 90+ C4 DIC do the job?
Old 06-25-2018   #4
the DIC is not model specific.. Base or ZR-1 should be the same
Old 06-25-2018   #5
Jeff,
Any chance the buttons need a cleaning or something along those lines? Or is it a mayter of simply teplacing the DIC?
Old 06-25-2018   #6
maybe cleaning, I would need to look at the switch, if I recall it is enclosed and if it does not work, replace it.
is the display not showing or is does not cycle through the functions?
Old 06-25-2018   #7
Jeff,
When I tap the Gauges button, it cycles thru the Trip and Odo displays not Oil/Coolant /Volts. If I press on it enough times and off center, it eventually will display the correct values. But a casual button touch brings up what is supposed to be shown using the adjacent Trip/Odo button.
IS the 90 DIC control any different?
Old 06-25-2018   #8
Jeff,
As a whole, yes 90-91 DIC is different then 92-96.. 92-93 are the same color wise
I have taken one apart.. PCB with buttons might be the same across years
Old 06-25-2018   #9
Ccmano
My replacement was not ZR-1 specific. I replaced the entire DIC although the button board can be replaced separately.
H
Old 06-26-2018   #10
Karl
Karl's Avatar
H
Were you able to purchase the digital cluster only or the entire display w/gauges?
Mine does not work and is blurred across all readings.
Thanks,
