Old 06-20-2018   #1
stuntmanmike
Default Replacement clutch disc?
Hi guys, I need to do a clutch replacement and did some searches on past posts, can't find a clear answer.
Something failed in there, rattling noises, car is not moving right now. I have to be prepared to replace the disc, bearings, pressure plate, and flywheel. The carolina clutch kits look attractive as they have most of what I need, but I'm reading mixed reviews.
I was satisfied with the performance of the stock setup, car is stock other than exhaust, I don't particularly want any new flywheel noise, and do not want to do this again anytime soon!
Thanks
stuntmanmike is offline   Reply With Quote
Old 06-20-2018   #2
S.hafsmo
S.hafsmo's Avatar
Default Re: Which replacement clutch to use?
There was a stock kit posted on the ZR-1 Registery facebook page.
If no OEM clutch disks are available, Haibeck recommended Centerforce 384100 disk. with 6 pcs .015" shims.
- '90 ZR-1
S.hafsmo is offline   Reply With Quote
Old 06-20-2018   #3
stuntmanmike
Thanks @S.hafsmo - just bought that clutch.
Also bought a Fidanza flywheel from him - i guess I'll use that if the stock dual mass is banged up.
Old 06-20-2018   #4
S.hafsmo
S.hafsmo's Avatar
Default Re: Replacement clutch disc?
Then I'd say you got a good deal. I gave quite a bit more for my set.
Last time I checked, Jerry still had one NOS flywheel in stock.
- '90 ZR-1
Old 06-20-2018   #5
Ccmano
Ccmano's Avatar
I have a good used OEM flywheel for sale if you need one.
H
90'ZR-1 #1461 Red/Black
05 C6 Z51 Red/Black Sold
Old 06-21-2018   #6
Vette73
There's going to be noise with that fidanza..Believe me..Mines a Sawz all till 2,400 rpm.
Vette73 is offline   Reply With Quote
