Everything is sold thanks for looking[Items added - New Pix] Everything is used. Shipping is extra...
Bolts and bolt sets, used OEM in good condition Complete set of OEM cam cover bolts 48/6 none striped. $50 2 Complete sets of Stock Plenum Bolts $15 per set. Bell housing to block 7 bolts $40 Trans to bell housing 5 bolts $35 Belt tensioner 1 bolt $15 Throttle body to plenum 5 bolts $40 Injector housing to head 20 bolts $50 AC compressor to block 3 bolts $20 AC pressure hose 1 bolt $10 Pressure plate to fly wheel 6 bolts $25 Bellhousing check cover 3 bolts $20 Fuel rail to IH 4 bolts $10 Starter to block 2 bolts $25 Electrical ground to block 2 bolts $10 Buy all the bolts listed here $150 firm. Secondary Vacuum Solinoid, 91’ $75 Air injection pump, 90’, $90 Cam Position Sensor, 90-95, $85 Transmission bell housing with fork and pivot that show very little wear, 90’, $199 Pressure Plate, looks to be a late production LT5 spec. replacement, 91’ $150 OEM GM Clutch Disc (~50% wear) $50 Knock Sensor 91’ $20 ZF6 Shifter & Linkage Complete Stock, Band New $115 PCV Hoses & Valves $85 Memcal Performace Chip 90’ Z-Industries not sure what they adjusted, typically timing, fans on earlier, skip ship elimination. $175 9 OEM Delphi injectors, 35k Miles/ 91’, 5 Secondary 4 primary, all ohm ~12.5, good if you need OEM, $50 Oil cooler, very clean, 35k Miles, 91’, $209 4 original 91’ coils 35k Miles, $25 each $80 all 91’ Coil base and tray (damaged) but functional. $175 Spark plug wire set, red AC/Delco replacements. Out of the 91’ $50 Oil filter housing adapter assembly 90’. $199 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Last edited by Ccmano; 11-23-2018 at 02:29 PM. |
![]() ![]() ![]() ![]() ![]() ![]() Last edited by Ccmano; 11-22-2018 at 10:06 AM. |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Last edited by Ccmano; 10-24-2018 at 08:57 AM. |
![]() Join Date: Oct 2013
Interested in the engine mount insulators. PM sent.
Tony - Tnova |
Fourth of July bump...
H ![]() |
Updated...
![]() Join Date: May 2012
Are you parting out the entire car?
#9 |
#10 |
Wow looks fantastic!
