![]() Join Date: Oct 2017
Anybody know where to get the "Y" that connects the fuel pump lines to the outlet?
Discovered mine has a small crack in it and is losing pressure. It is the one connecting the 3 hoses together on the sending unit assy. Believe it is 5/16" on the pump sides and 3/8" on the outlet side. Also, what hose does everybody use to replace the original on the sending unit? Thanks for the help.
Kenny 1990 #442 ![]() |
![]() Join Date: Aug 2015
#3 | |
![]() Join Date: Jul 2004
You would need to salvage that off another pump assembly.
Or spend $200 plus dollars for a whole new assembly. I have a couple of these let me check that piece and see if Its usable. Btw what you think its worth?
![]() Join Date: Jun 2013
This would be an option:
https://www.usplastic.com/catalog/it...SABEgLcJPD_BwE You just might need a different clamp to tighten the 3/8 hose onto the 5/16 barb. I looked into this awhile back. |
#6 | |
Thanks for the offer. I am concerned that an original plastic one would probably be brittle just like mine is. Nearly 30 years is a long time for plastic to remain serviceable. I was able to do a repair on mine and everything is holding fine for now, but I am checking into several options for a better permanent replacement. The 2 different size hoses sort of throws a kink into buying one off the shelf. I'll report back if I come up with something.
#7 | |
They have one for 3/8" also, but I am pretty sure 3/8" hose will not hold securely on the pump outlets. Thanks for the reply.
![]() Join Date: Aug 2014
There might be something useful in this thread http://www.zr1.net/forum/showthread....t=fuel+fitting
If you haven't already seen it.
1990 black on black #1042 - sadly - sold 1993 Ruby #140 - stock 1991 QB #1608 - heads and top end ported, Watson headers, B&B 3"exhaust, Haibeck chip, 4.10 gears |
