Old 05-17-2018   #1
Default Lug Nut Woes
Of course, the last lug nut I'm trying to get off and NOT HAPPENING!
Hate the locking lugs. This one slips out every time I put any torque on it. Almost like it's stripped.
Is there anything I can try before I take the car up to the local tire shop?
Argh!
Old 05-17-2018   #2
lfalzarano
Default Re: Lug Nut Woes
Tire shop has the expertise to remove it. Most likely on the last tire change they installed the wrong lock. Happens all the time! You need to find the match to the other 3!
Lou
Old 05-17-2018   #3
conesare2seconds
You can try a Gator socket. A good tire shop can sometimes get it but it’s luck of the draw whether they have the right tool.
Old 05-17-2018   #4
DRM500RUBYZR-1
DRM500RUBYZR-1's Avatar
https://www.amazon.com/Performance-T...70_&dpSrc=srch
This will take care of it.
Just order the correct size
Marty
p.s. then remove all of the locks!
Old 05-18-2018   #5
Thanks all!
Old 05-18-2018   #6
jss06c6
Marty's recommendation should work. In the interim, your lock nut socket appears to be worn out on the tips. Can't get a bite that way. Are you using an impact or regular wrench? Two things you might try in the interim.. grind off some of the end of the lock nut socket a bit so that the ends are squared off again, then retry with an impact while pressing the socket into the lug nut as hard as you can, to prevent it from coming out..
Sent from my QTAIR7 using ZR-1 Net Registry mobile app
Old 05-18-2018   #7
Marty
Marty, you are a life saver!!!
Old 05-18-2018   #8
Young1
Young1's Avatar
I once on the road took a 12 point socket of just the right size and hammered it over the locking lug. Got it done in a pinch.
