Old 05-14-2018   #1
BigIke
Default High amp draw - diagnostic assistance
I've burned up two alternators pretty quickly. After the last install, I put the original pulley on (larger thinking my constant 7000 rpm adventures were killing alts...) but the voltage was very low at idle with AC on.
When The Car is hot and both fans are on high speed, the voltage is low (12vdc)when cold and the AC is on the voltage drop is the same or a little lower.
Amp draw is 15-17 on both fans, and around 20 on the AC blower motor.
Recon I need cooling fan motors or a new blower motor?
The blower doesn't feel like it blows as hard as it once did...
Thanks Jay.
PS. Haven't posted in awhile but I'm still beating the snot out of this thing, and loving every minute!!!
Sent from my SM-G950U using Tapatalk
Old 05-16-2018   #2
Young1
Young1's Avatar
Default Re: High amp draw - diagnostic assistance
Are you sure you are getting 124 amp alternators?
Steve Young
Second Owner
SOLD
SOLD
Old 05-16-2018   #3
S.hafsmo
S.hafsmo's Avatar
You're certain that the battery is in good condition?
- '90 ZR-1
S.hafsmo is offline   Reply With Quote
Old 05-17-2018   #4
BigIke
The Alternators are from Jerry, the only way to go IMHO. The Battery is New, but it's done it with two or three different batteries.
I'm putting it on the lift after work to install my Watson Headers and New ZF6.
When i get it running again, i'll write down my current draw for: Fan1, Fan2, AC Blower Motor, and Total Current load. It's got to be something easy.
It only shows low VDC when the coolant temp is high @ idle or when the AC is on @ idle.
Old 05-18-2018   #5
Young1
Young1's Avatar
Could it be the bearings in the fans are dry and causing too much friction and a high amp load? It might be worth looking into.
Old 05-18-2018   #6
BigIke
I have the inner fenders off for header install that has grown to motor mount replacement and header install. I'll take it off tomorrow and spin it. Thanks for the idea!
