Old 05-06-2018   #1
Mr.Yuck
Default Hidden shift light in the vent.
I'm looking to add a vent mounted shift light does anyone know where I can purchase one?
Sent from my 2PS64 using Tapatalk
Mr.Yuck is offline   Reply With Quote
Old 05-06-2018   #2
gtcollins@maxnet.co.nz
Default Re: Hidden shift light in the vent.
I made my light with leds and used a auto meter switch
Glen
Sent from my SM-G930F using Tapatalk
Old 05-07-2018   #3
My light is hidden in the AC vent and was made by Raptor.
90 #1202
Sans secondaries
SW headers, X-pipe, MF muffs
Old 05-07-2018   #4
dredgeguy
dredgeguy's Avatar
Mine is from Harlin and hidden in the vent. Mark Horner did a group buy for Wazoo when he was still in DC and several of us had it installed.
Charlie
__________
Dredgeguy
Dana 4:10 gears
Polished LT5 by Haibeck
Old 05-07-2018   #5
A1990
A1990's Avatar
Jeff check with Mark Horner as he has the contact information for Harlan. He also wrote an article in the HOTB on installation.
We did a group buy last year on the shift lights and if there is enough interest we might do another one.
If you don’t have Mark’s contact info let me know.
Dennis Fierstein
90 ZR-1 #2562 Atomic-Z
ZR-1 Net Registry Chairman of the Board
ZR-1 Net Registry Treasurer
A1990 is offline   Reply With Quote
Old 05-08-2018   #6
Mr.Yuck
That's exactly what I'm looking for. I just received a message from a member that had a extra one through Mark's group buy. This is a perfect example of why the ZR-1 net registry community so great. All of us networking to help each other keep our pieces of History rolling. Thank you all.
Old 05-10-2018   #7
Flyman 27
Flyman 27's Avatar
If you order a new one from Harlan (available online) you get a choice of LED color.
If you tell him you want to remote mount it in a Corvette, he will install extended leads to make it easy to install at no extra cost. Good guy to deal with. All units are made to order.
91-#1935 Black/black & gray, Haibeck 500
Cams by Pete
Flyman 27 is offline   Reply With Quote
Old 05-10-2018   #8
Yup! I like mine hidden in that very spot as well, Charlie!
The (RAPTOR light, in my case) is about 2.5" long and about as big in diameter as a the barrel of a Uni-ball (ball point [click-click]) pen. The wires were long enough to reach the "C-1" connector by my left toes where I accessed the tack wire and a chassis ground.
By referencing my Dynojet graph, my power curve peak (flattens out) between 6800 and 7100 rpm. But, my 1/4 mile times are better if I back the trigger down to ~6800...allowing for reaction time, I recon (and NO wise crack, thank you very much! LOL!).
90 #1202
Sans secondaries
