Old 05-01-2018   #1
9T1 Red ZR1
9T1 Red ZR1's Avatar
Default Universal joint question
Hello,
I am replacing my driveshaft u-joints. The old joint at the yoke in the front flops around as you turn the drive shaft (once it has been removed from the car). The new Spicer joint is stiffer. It moves freely and completely but "holds" its position as I turn the driveshaft parallel to the ground. Is this normal or do I have the caps pressed in too tight? How loose should the new joint be?
Thanks,
Bill
LT5 Red/Red
9T1 Red ZR1 is offline   Reply With Quote
Old 05-01-2018   #2
S.hafsmo
S.hafsmo's Avatar
Default Re: Universal joint question
Both my old and new joints held the yoke when rotating the shaft. Replaced them today.
- '90 ZR-1
S.hafsmo is offline   Reply With Quote
Old 05-01-2018   #3
9T1 Red ZR1
Thanks, I appreciate the information.
Bill
LT5 Red/Red
