Old 04-30-2018   #1
Norwegianmopar
Norwegianmopar's Avatar
Default Glass top
Hi guys. Found a ZR-1 I like, but it's missing the glass tops. Are those the same on any 91-95 Corvette?
Sent fra min SM-G955F via Tapatalk
Roy Martin
1994 ZR-1 #112 Admiral Blue/Black
Dana 4:10
Aluminum flywheel
Corsa exhaust
Watson headers
Haibeck chip
470 HP/399 RWHP
1991 ZR-1 #400 White/Red (SOLD)
Dana 4:10
Powder coated engine
Haibeck performance chip
Borla exhaust
Norwegianmopar is offline   Reply With Quote
Old 04-30-2018   #2
DRM500RUBYZR-1
DRM500RUBYZR-1's Avatar
Default Re: Glass top
Yes, the ZR-1 and base cars use the same top, so any one from at least 90 up will work just fine.
Marty
Old 04-30-2018   #3
Norwegianmopar
Thanks Marty [emoji106]
Roy Martin
Dana 4:10
Aluminum flywheel
Corsa exhaust
Watson headers
Haibeck chip
470 HP/399 RWHP
Dana 4:10
Borla exhaust
Old 04-30-2018   #4
WVZR-1
When buying you would want to verify it's a 'genuine' GM I'd think or a verified 're-lens' from Melrose. Needs to have a metal molding and I'd try to confirm with a snapshot of the 'glass-bug' that's centered very near rear edge. I thought I had a good snapshot of a transparent top 'glass-bug' but I can't find it.
Old 04-30-2018   #5
89 tops will work too.. I have my acrylic top from my 89 on my 90
-=Jeff=- is online now   Reply With Quote
Old 04-30-2018   #6
Norwegianmopar
What is the correct tint on the glass tops, bronze or blue?
https://www.ecklerscorvette.com/exte...nd-t-tops.html
Roy Martin
Dana 4:10
Aluminum flywheel
Corsa exhaust
Watson headers
Haibeck chip
470 HP/399 RWHP
Dana 4:10
Borla exhaust
Old 04-30-2018   #7
Norwegianmopar
Or is it smoke tint..?
Roy Martin
Dana 4:10
Aluminum flywheel
Corsa exhaust
Watson headers
Haibeck chip
470 HP/399 RWHP
Dana 4:10
Borla exhaust
Old 04-30-2018   #8
Norwegianmopar
http://www.corvettepartsworldwide.co...tCode=8-303XBZ
Roy Martin
Dana 4:10
Aluminum flywheel
Corsa exhaust
Watson headers
Haibeck chip
470 HP/399 RWHP
Dana 4:10
Borla exhaust
Old 04-30-2018   #9
jrd1990zr1
jrd1990zr1's Avatar
Do you have the window sticker/build sheet? That should tell you.
1968 convertible Lemans Blue,
1986 coupe Medium Blue NCRS Top Flight (sold),
1990 ZR1 #2529 Red NCRS Regional and National Top Flight (sold),
1990 ZR1 #2124 Charcoal Metallic NCRS Top Flight 2010 & 2018,
2003 Anniversary Red Convertible (sold)
Old 04-30-2018   #10
Norwegianmopar
I called Melrose Corvettes in IL and he told me to go for the blue tint. The bronze will make the red interior look like poop... [emoji23]
Roy Martin
Dana 4:10
Aluminum flywheel
Corsa exhaust
Watson headers
Haibeck chip
470 HP/399 RWHP
Dana 4:10
Borla exhaust
