Old 04-26-2018   #1
TealZR1
Default Short idle/engine Issue
My 91 on cold start is perfect. Idles down to 650 but always when reaching about 110 degrees it bogs down (runs rough) for about 20-30 seconds with rpm's decreasing some. After 20 seconds or so is comes back up to normal and drives perfect through normal operating temps. But again does this about every time. Had on scanner (ok) and no warning lights come up.
Thanks in advance of any help.
TealZR1 is offline   Reply With Quote
Old 04-27-2018   #2
Ccmano
Default Re: Short idle/engine Issue
I would check the fuel pumps and fuel filter first. Sounds like your primary pump is on its way out. There are some excellent threads on the subject if you care to search.
Post 7 in the following thread is excellent.
http://www.zr1.net/forum/showthread.php?p=136108
H
Old 04-27-2018   #3
110F is 43C which is about where the fueling transitions from Open Loop to Closed Loop. That transition may be a bit lean before it continues to warm up and the ECM adjusts fueling accordingly.
Old 04-27-2018   #4
Actually this is somewhat normal and consistent with both my cars. Yeah it does that as Dom states. Never throws a code but its like the idle is adjusting. Any way to video this stumble ?
Old 04-27-2018   #5
Altho that can be addressed w tuning so the transition is nearly seamless.
Old 04-27-2018   #6
TealZR1
Thanks all for responding to my idle issue. Per Goldcylon's suggestion here is a video. About 15 seconds in it starts to stumble but about 32 seconds it goes back to normal.
Thanks!
https://www.youtube.com/watch?v=SNqW...ature=youtu.be
Old 04-27-2018   #7
Correct
Old 04-27-2018   #8
Thanks!
Yeah needs some fine tuning there. Lots of input from close loop to open loop. Condition of o2 sensors, TB, IAC all play into this
Old 04-27-2018   #9
jss06c6
Agree with Dominic that's it's likely an open to closed loop issue, but have a question... Is this a relatively recent development, or has it always done this? Have you checked and cleaned your O2 sensors? Was the tune changed and it subsequently started doing this?
Sent from my QTAIR7 using ZR-1 Net Registry mobile app
Old 04-27-2018   #10
TealZR1
thanks JSS and Gold - yes fairly recent since I had an antifreeze leak at the TB. I had Haibeck service the TB and reinstalled but I am wondering if the antifreeze possibly started another issue like contaminating one or both 02 sensors.
If I get it on a scanner next week what should I look for?
