Old 04-23-2018   #1
Livin' in the 80's
Livin' in the 80's's Avatar
Default Rear Window Drains-Pro's and Cons-installation tips and/or video
I went through the forum and there is very little on this modification. I am replacing the rear weather strip as soon as it comes in and I might consider doing the drains at the same time. I also went through youtube as well. If I choose to do this, I don't need to drill into a harness or a panel that goes in the car.
:Eagle:[URL=http://s653.photobucket.com/user/craigwhite84/media/Kelly%20Boat/IMG_0468a_zpso50qvl1y.jpg.html][IMG]http://i653.photobucket.com/albums/uu256/craigwhite84/Kelly%20Boat/IMG_0468a_zpso50qvl1y.jpg[/IMG][/URL]
1990 ZR1 Black/Black #2317
Livin' in the 80's is offline   Reply With Quote
Old 04-23-2018   #2
Mystic ZR-1
Mystic ZR-1's Avatar
Default Re: Rear Window Drains-Pro's and Cons-installation tips and/or video
Don't bother....
Why drill 2 more holes in your car?
"Borrow" your Bride's turkey baster
to remove the water that ends up there.
Whether or not you tell her you borrowed
it is up to you...
Old 04-23-2018   #3
lfalzarano
I use a Sg Tool Aid 14600 Rubber Bulb Battery Filler from Walmart for $4. I keep it in the cleaning bucket and it sucks out the water in those corners. And can be used to fill your fillable batteries!
Old 04-23-2018   #4
Livin' in the 80's
Don't bother....
it is up to you...
I currently use a Mighty vac 7400.
Old 04-23-2018   #5
Livin' in the 80's
I would still like to see it being done and where it would be drilled.
Old 04-23-2018   #6
KILLSHOTS
Yeah, when I had my Z, I went so far as to buy the drains. When they arrived, I went to install them and just couldn't drill holes in the car. I got one of those rubber bulb syringes for babies and it worked great.
Old 04-24-2018   #7
QB93Z
QB93Z's Avatar
I installed the drains on two ZR-1's and have been very pleased with the set up. I don't have a video, but the installation is straight forward. I used silicone sealant to fix the flared tube in place and it has held up fine for many years.
1990 Black ZR-1 - sold
1993 Quasar Blue ZR-1
1994 Competition Yellow ZR-1
1995 Dark Purple ZR-1
Maryland State Coordinator
Old 04-24-2018   #8
Livin' in the 80's
Can you take a pic of where they are mounted?
