Went to look at this ‘91 this afternoon, it’s number 360. It’s a one owner car, unmodified with the exceptions of an update to ‘92-‘96 exhaust and Hella headlights. The body is straight, panel fit is very good, I could not find evidence of an accident. Original window sticker and some other documentation come with the car. I was unable to drive it this visit, it was heavily blocked in by other cars in the back of the showroom. I was able to start/rev the car. Was able to talk to the owner of the dealership, he did not try to mislead me and appeared to be a straight shooter as well as knowledgeable about Corvettes.
Link to Z: http://www.arenamotor.com/1991-Chevr...043201/6403086 What it needs:
What I noticed:
My main concerns were the vibration/audible “bumping sound” at start up and headlight motors continuing to run which make me question if the car has electrical gremlins. Dealer has it listed for 20k but will take 17k. I look forward to and would appreciate any input on the car. Thank you. B17Crew ![]() Last edited by B17 Crew; 04-19-2018 at 04:17 PM. |
![]() Join Date: Nov 2011
If it's mechanically sound, looks pretty good at 17K. If there are gremlins, FBI crew is not that far away.
![]() Join Date: Dec 2007
If you do your own work the headlights is a nonissue about 50 bucks in parts needed to fix.
90 Chevy ZR1 LPE #2315 'SOLD' 90 Chevy ZR1 LPE #2774 'SOLD' 91 Chevy ZR1 Callaway aerobody 91 Chevy ZR1 #1512 91 Chevy ZR1 #951 95 Chevy ZR1 #338 'SOLD' 91 BMW 850i 94 BMW 850csi 95 BMW 850csi 94 Lotus Esprit S4 07 Benz CLS550 06 BMW M5 "SOLD" |
#4 | |
Welcome to the addiction... Answered some of your questions above. Here a list of things to look at. I'm sure I missed few but here you go. Frankly, to me, $17k is high for a 91 in this condition and miles that potentially needs work. Known issues for the ZR-1, some related to higher miles some not. Injectors - 90-92 must be replaced. Vacuum leaks to the secondary throttle system. Secondaries operable? Ingnition coils and wires replaced? Timing chain noise at start (normal to a some degree on 90's) Starter, does the car start consistently Oil leaks especially the pan and oil cooler lines Fuel pumps, have they ever been replaced? Is it throwing any engine, abs or body codes (SES light on?,multiple possibilities here) Are any DIC lights on. (Multiple possibilities here as well) Is the adjustable shocks system working Windshield delamination A/C functionality (compressor is unique to the Z, cooling capacity lower) Power switch functionality and keys (are there 2) Transmission syncro's, (first gear is always noisy) shifter alignment can mimick synco problems. Clutch functionality (they all let in high, was it ever changed) Egr system on later models Engine mounts C4 Issues Head lights operable Radiator blocked or simply clogged, electric fans operable Wheel bearings Suspension bushings Condition of all door, top and hatch seals Glass roof cracking Instrument cluster functionality especially the tach (tends to read high with age) also note the lighting of the cluster. DIC button functionality Steering wheel excessive movement Radio functionality (especially speaker amps) and antenna Sport seat functionality (transmission, switches, pumps and bladders) Door window switches Door window lifter and internal rattles Fuel tank bladder collapse (results in small capacity) Differential noise (whine) Good luck H ![]() Last edited by Ccmano; 04-19-2018 at 06:09 PM. |
#5 | |
B17Crew ![]() |
#6 | |
B17Crew ![]() |
#7 | |
I figured the dealer purchased the car from the original owner somewhere in the 14k range. Thank you for your direction on pricing as well! B17Crew ![]() |
#8 | |
#9 |
#10 | |
H ![]() |
