![]() Join Date: Nov 2010
Doing DRM coilovers soon, and figure I should replace the shocks since I have no idea how many miles/years on on the current ones. What’s the best place to buy new ones, and should I do anything other than stock valving? Car is mainly weekend use, and I do multiple back road runs each year on twisty roads. Would t mind a little firmer rode for better handling.
Guess I should have clarified, yes it’s a DRM coilover setup (slightly used) for factory FX3 shocks. Pete will be doing the install and can machine the shocks.
![]() Join Date: Aug 2017
Right now FX3 shocks are on back order everywhere from Bilstein. As far as I know you won't find a complete set. Also if you send your FX3's out for rebuilding, the parts are on back order (in that boat right now). I was told sometime in April last time I checked but not holding my breath.
![]() Join Date: Jul 2007
Can you feel a difference with your FX3 now? If so, have Pete groove what you have and install them, drive it and determine if you want custom valving.. I drive my car on weekends and such, like you, I have stock shocks with coilovers and it seems fine for me.
Yes, can definitely feel a difference with what I have now. Tour is somewhat "floaty", Sport is more buttoned down (and where I typically leave it), and Performance is a little stiffer (although not nearly as much difference between Sport & Performance as Tour to Sport).
#6 | |
![]() Join Date: Jul 2016
#7 | |
Bilstein will do aftermarket shocks, just not the original OEM's. Someone at GM complained, all it does is hurt us, the customer in the end. |
Guess I'll just go with the ones that are on the car and just rebuild them later if/when they fail.
#9 | |
On another note, while I was waiting, I installed a set of ridetech adjustable shocks (no coil overs, stock suspension) and was very impressed. You loose the FX3 but I never changed the setting anyway so no biggie. |
#10 |
![]() Join Date: Mar 2015
What's the difference between the coils transverse leaf springs when driving
Regards Glen Sent from my SM-G930F using Tapatalk |
