![]() Join Date: Feb 2018
Any tips on disconnecting the passenger side O2 sensor on a 1990? It's jammed way up in there and I don't see an obvious way to get to it.
I just got the car and haven't picked up the service manuals yet - still deciding between print and online. |
![]() Join Date: Sep 2016
I did it recently. Remove the angle frame brace. It looks like it holds up the motor but it doesn't. The connecter is then accessible. Not at all difficult.
#3 | |
Be sure to install a Denso or a Bosch. The cheapies don't work.
I bought a pair of Bosch on Rock Auto. Good pricing you just have to wait
![]() Join Date: Nov 2007
I concur with Dominic. The Bosch (in particular) would become intermittent at times - causing me "a little" angst!
But, the REAL angst was accessing the sensors to remove and reinstall them! The "fix' was plugging the top mount bungs and installing new ones facing laterally toward the frame rails. What a good idea that turned out to be! (I placed them at about 80-85º from vertical to my SW header collectors. I've NO problems with them being damaged when bottoming out (i.e., speed bumps, etc), and heaven knows I've tested them!!) O2 (weld in) Bungs: Summit Racing: #SLE 30115 Last edited by Paul Workman; 03-05-2018 at 07:41 AM. |
#9 | |
Per XfireZ51 and your advice, I went ahead and ordered the delco sensors from rock auto, since I only had one useful bosch sensor from my amazon order. -Stephen |
#10 |
Plugging the thing in is a real challenge. What I did was put a wad of dumdum on the end of a long thin screwdriver and started the plug into the other end and then used another long screwdriver to push the plug together. Dumdum is seam sealer.
