![]() Join Date: Feb 2011
I had a suspected tire pressure wheel sensor removed since it was not properly aligned 180 degrees from the valve stem from the last tire installation. Actually, the GM tech broke it and they are ordering a replacement band.
From prior threads it was my understanding on a 1990 the Tire Pressure Warming System would not go off on the DIC if a wheel sensor is removed. After driving about 5 miles, the system said it failed and needed service. Did it error out since only one wheel sensor was removed or it will only be happy if all of the wheel sensors are removed? Sent from my iPhone using ZR-1 Net Registry |
I pulled all the wheel sensors off my last 90 and had no lights come on. To me, that system was not ready for prime time anyway. Those huge sensors in the wheels were just asking for problems especially when the tires were changed. That and the system could not tell you which tire was low or sensor was bad.
H ![]() |
#3 | |
#4 | |
GOLDCYLON - 91 ZR-1 #2014 GOLDCYLON - 90 ZR-1 #2794, 4L60e (Formerly Schrade's) GOLDCYLON - 11 CTS-V Arizona State Director ![]() 91 WHITE/BLACK #2014. 380 P&P&PCed,Ported Heads, Jeal Long tubes, Corsa Exhaust/FIKSE FM-5s /LED TLs, LED Headlights, Front Wilwood 6 piston narrowlite calipers and rear Wilwood caliper street shop mod,CNCed Coolant Pipes,TPI Cvr,Filter cover,Stainless Bolts, DRM/DOM PROM /ZFDOC mod build #102,DRLs,BMAD with stainless Debris Screen,Coplan Air Blaster, Pioneer APP Radio 4,Brey-Krause HB,Sub Bar,Fire extinguisher seat mount,DRM Coilovers,LEDs everywhere,Compass mirror (orange),V1 DIC hidden display, Homelink sun visor, Carbon Fiber top x3 and APSIS Carbon Fiber interior, APSIS CF Steering Wheel/NAPA Leather, Banski trailing arms, Guldstrand front suspension,urethane bushings from Prothane (total suspension) ZFDoc drive shaft safety loop, raptor shift light (orange),AO engineering louver front plate, Console seat cushion, 96CE seats with black custom Sheepskins, ss billet catch can,Viper remote entry/alarm,Cragar Rear Louvers,LED side louver lights, Dewitts Radiator with SPAL fans and a Woods 160 T-Stat 90 RED/BLACK #2794. 4L60e Automatic Stage V by RPM Transmission, TCI Dedicated TCM, OBX Stainless Headers, Corsa Exhaust, SAN Secondaries and Haibeck PROM, Exotic Muscle Coil overs, LED Interior Lights, LED Tail Lights, LED Headlights, 94 Sport seats with black custom Sheepskins , Cragar rear louvers, GS Front calipers, Banski Trailing arms, APSIS Carbon Fiber steering wheel, Front and Rear Baer Eradispeeds, DRLs, Guldstrand front suspension,urethane bushings from Prothane (total suspension), Dewitt's Raditor with Dual SPAL fans and a Haibeck 170 T-Stat 11 RED/GREY CTS-V Last edited by GOLDCYLON; 02-21-2018 at 12:36 AM. |
![]() Join Date: Jul 2007
with the advancements in Tire pressure tech, I removed mine when I bought the car..
I might have one sensor hanging in the garage. I was looking at this: https://www.amazon.com/dp/B01LZME9Q2...&pd_rd_w=Zanmr does not even require a permanent install
Can you describe the paper clip method and what that does?
![]() Join Date: Mar 2010
I removed all my sensors from both my cars. Having one break going 100+ mph was not cool.
Interestingly enough, on my '91, no warning light ever appears. On my '92, the warning light appears after driving for a little while (~ 15 mins?). John
1992 #043, Aqua/Gray 40k miles |
