Old 01-25-2018   #1
9T1 Red ZR1
9T1 Red ZR1's Avatar
Default Fidanza users
I have a question for anyone using the Fidanza flywheel. I get a slight vibration/rattle from my transmission in only 5th or 6th gear when the RPMs are between about 1500 to 2000. Once above about 2000 rpm, it goes away and in any other gear in that RPM range, there is no vibration. I have C-beam plates and the torque is correct on them. Is this something anyone else has? Suggestions if it shouldn't be happening?
Thanks,
Bill
LT5 Red/Red
9T1 Red ZR1 is offline   Reply With Quote
Old 01-25-2018   #2
Default Re: Fidanza users
Thanks,
Bill
No I don’t get any vibration at any time other than stopped in neutral.
What trans fluid are using?
Is this happening at steady cruise or during accel/decel?
Former ZR-1 Registry - BOD
1984 Corvette Z-51/4+3 SOLD
2014 Honda VFR Interceptor DX
Old 01-25-2018   #3
mgbrv8
I don't get vibration just a noise(slight rattle) at idle because the dual mass isn't there to dampen it out anymore
Dave
Old 01-25-2018   #4
9T1 Red ZR1
I am using the Amsoil fluid in the transmission. It only happens when accelerating. it goes away as soon as I let off of the gas. It's funny, there is almost no rattle at idle in neutral. I forgot to mention, I have the Hurst shifter.
LT5 Red/Red
Old 01-25-2018   #5
We've both got Fidanza FWs in our Zs. Like Dom, except for idling in neutral, no rattling at any speed/load condition.
You mentioned a Hurst shifter. Tho completely different from a ZF shifter, but THAT or something related to the shifter sounds very similar to what I experienced with a shifter on a '69 SS Malibu: worn bushings rattled under heavy loads. Furthermore, it sounds like there is a resonant frequency - more evidence of something loose (but pretty sure it's NOT the FW). I think I'd look at the shifter and the C-beam bolts/plates first.
90 #1202
Sans secondaries
SW headers, X-pipe, MF muffs
Old 01-25-2018   #6
9T1 Red ZR1
Thanks for the replies. I will look into the items you suggested.
Bill
LT5 Red/Red
Old 01-25-2018   #7
BTW, I have a Hurst shifter and Intake/Exhaust cams.
Old 01-25-2018   #8
Vette73
I get the typical noise up until around 2,300 RPM......Sometimes it sounds like an electric saw as I am accelerating......In sixth gear at the RPM you specified,it sounds like a motor boat......I just leave it in fifth for that matter if I'm doing 60-65....
Car has obx headers and exhaust .....Car is fully ported with intake cams...
Sent from my LG-TP260 using ZR-1 Net Registry mobile app
Vette73 is offline   Reply With Quote
Old 01-25-2018   #9
Are u describing the Fidanza or exhaust drone?
Old 01-25-2018   #10
Vette73
The fidanza I have noise until like 2,300 RPM,after that it goes away.......Sixth gear is def. the exhaust drone....
