Old 12-05-2017   #1
Flyman 27
Flyman 27's Avatar
Default What winter projects are you planning for your Beast?
I purchased my 1991 ZR-1 in late summer this year. The PO gave me a list of things that needed repair. I repaired everything on his list. This is the rest of my list I have after spending a couple months working on it & driving it.
My list is long, but almost all of it needs to happen before the next driving season.
** Means I have the materials already.
Replace leaking shocks.
R&R leaking radiator, hoses, Thermostat, temp sw & heater hose coupling.
Remove dash, R&R clogged heater core & blower door actuator.
R&R broken front side light assemblies.**
Polish fog light lens's.**
Replace plug wires & coils, fix oil leak in valley & Vacuum leaks.**
Remove IP & repair Tachometer, replace IP lights.**
Install Viper remote door lock system.**
Remove driver's side dash and replace:
Starter switch**
Ignition switch**
Turn signal switch**
Column pivot from Mark H.
HVAC controller, remove & rebuild**
Install starter circuit relay**
Replace Tack resister to correct**
Replace IP light bulbs
R&R drooping headliner.**
Replace both O2 sensors**
Bleed brakes (fluid is black).**
R&R leaking door seals.
Install new window bumpers.**
Install new shift boots (old ones are stiff & crispy, hard to shift).**
R&R oil bypass valve & oil temp sender.**
Try to find oil leaks & fix.
I would love to swap out the aluminum flywheel & revert back to the dual-mass flywheel & clutch assembly. The knocking & trans noise really bugs me.
How's your list? Short or long? About 80% of my list is absolutely necessary IMHO.
[SIGPIC][/SIGPIC]
91-#1935 Black/black & gray, Haibeck 500
Cams by Pete
Flyman 27 is offline   Reply With Quote
Old 12-05-2017   #2
TX '90 ZR1
TX '90 ZR1's Avatar
Default Re: What winter projects are you planning for your Beast?
Flyman27.
You have a pretty impressive list there !!
Mine is not nearly so long.
#1- Remove radio receiver & have repaired.
#2- Repair inoperative lumbar pump.
#3- Locate & repair small oil leak.
#4- Detail engine compartment.
#5- Detail underside of vehicle including wheel wells.
I'll probably find more as I go, but will be happy to get these done. Working on it is like a good therapy session !!
Old 12-05-2017   #3
Starter switch**
Ignition switch**
Replace 12 year old tires.
Boy-Howdy! That'll keep you outta the bars at night! Must have a heated garage? I'd freeze my tushe' off in MY garage
Old 12-05-2017   #4
Flyman 27
Flyman 27's Avatar
Yes Paul, the garage is heated. I installed a small overhead furnace in my garage a few years ago. A "Hot Dawg", I highly recommend them. Pretty inexpensive & heats the garage quickly.
I hope to work on it a little here & a little there, not any marathon sessions. It's work, but I want to enjoy it as much as possible.
[SIGPIC][/SIGPIC]
Cams by Pete
Old 12-05-2017   #5
Ccmano
Just finished...
Flywheel Fidanza, clutch disc, pressure plate, pilot & throwout bearings
Clutch master, slave & steel braided line.
Drive shaft U-joints and C-Beam Plates
Hurst Shifter
Engine mounts
Oil temp & pressure sensors
Power Steering hoses
Headers, Obx Exhaust & new O2 sensors
Front shock bushings
DIC panel replacement
Instrument pod trim replacement
Moving forward she will need a tune (Dom you listening)
Driver seat transmission replacement
Fix the tach (usual incorrect readings)
Alignment
Not sure for this winter but if time and funds permit
Replace all suspension bushings
Port the plenum and injector housings plus power coat.
New carpet.
It’s an on going project...
H
Old 12-06-2017   #6
My list is in process:
- Replace radio
- Replace dash pad
- Replace one piece of carpet in hatch
- Rear Camber Rods
- Side yoke seals on Differential
- Add my Delayed Accessory bus since dash is out
- Fix door chime (this one is done)
I am sure I have a list of other things I have put off that I need to do as well
Old 12-06-2017   #7
Well for my 91 nothing (She's done)
for the 90 A few things
1. Braided stainless oil cooler lines
2. Oil change because of (See above)
3. Change PCV valves and install neoprene upper and lower PCV hoses
4. Install Andrew's compass and auto dimming rear view mirror
5. Install rear Eradispeed rotors and probably rear pads
6. Install -=JEFF=-'s LED side marker mod
7. Upgrade front J55 calipers to 96 GS calipers and probably front pads
8. Replace the front radiator fans (One is making a noise)
9. Change rear dog bones (Trailing arms) to neoprene
Old 12-06-2017   #8
JThomas
JThomas's Avatar
1. Continued cleanup
2. Track down small oil leak
3. Shop for a new radio or upgrade factory unit with modern specs
4. Purchase new glass roof
5. Sort out minor height difference in rear end (Rear spring?)
6. Install new bearings in left headlight, so it rotates smoothly
Joe Thomas
Corvette Club of Michigan
NCRS-Michigan Chapter Member
NCM Master Ambassador
Former NCM Board Member
1991 ZR-1 Melon Copper Metallic/Black
1992 ZR-1 Bright Red/Black (Sold)
1995 ZR-1 Bright Aqua/Gray (Sold)
2012 ZR1 Super Sonic Blue / Dark Titanium
JThomas is offline   Reply With Quote
Old 12-06-2017   #9
Young1
Young1's Avatar
Winter projects? That's my driving time. I do my projects in the summer when it's too hot to run around with the target off.
Old 12-06-2017   #10
Joe,
I suggest the new radio route. If you were going NCRS then stock. But you have changed the color.. go aftermarket. The Sony XAV-AX100 is a nice unit and the XAV-AX200 adds DVD player and SXM. Both have Car Play and Android Auto capability
