Old 10-25-2017   #1
Ccmano
Ccmano's Avatar
Default Flywheel Holding Tool
Curious what everyone is using to hold the flywheel when torquing the bolts?
H
90'ZR-1 #1461 Red/Black
05 C6 Z51 Red/Black Sold
Old 10-25-2017   #2
BigJohn
BigJohn's Avatar
Default Re: Flywheel Holding Tool
Dowel pins
Old 10-25-2017   #3
Originally Posted by BigJohn View Post
Dowel pins
Can you expand on this?
Old 10-25-2017   #4
Jagdpanzer
Jagdpanzer's Avatar
Wedge a short pry bar in between a cast in web or one of the bell housing dowels and the flywheel ring-gear teeth
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 10-25-2017   #5
Ccmano
Ccmano's Avatar
Wedge a short pry bar in between a cast in web or one of the bell housing dowels and the flywheel ring-gear teeth.http://i540.photobucket.com/albums/g...pso0itmr9d.jpg
Link is not working...
Old 10-26-2017   #6
jss06c6
Hans,
Should be able to slip the FW onto the dowel pin and start one FW bolt to hold the FW in place. Run the others in with a little red thread lock, then torque all if them in..[ATTACH]6718[ATTACH]6719
Old 10-26-2017   #7
Why not a flywheel holding tool?
https://www.summitracing.com/parts/otc-4801
Old 10-26-2017   #8
Ccmano
Ccmano's Avatar
Originally Posted by jss06c6 View Post
Hans,
Thanks Steve,
I was referring to holding the flywheel steady so it doesn’t rotate with torquing.
Going try this tool tomorrow.
H
Old 10-26-2017   #9
Amazon Prime
https://www.amazon.com/Performance-T...flexwheel+tool
Old 10-27-2017   #10
jss06c6
Originally Posted by Ccmano View Post
Thanks Steve,
H
Got it, now I understand your note.. I didn't need one. Engine compression was sufficient to allow me to torque all bolts..
Sent from my QTAIR7 using ZR-1 Net Registry mobile app
