Old 10-22-2017   #1
Default A question about dropping the exhaust?
I'm going to drop the exhaust to install the Hurst shifter and BB C Beam plates,what gaskets will I need at the exhaust collectors?
Old 10-22-2017   #2
bhedberg
Default Re: A question about dropping the exhaust?
The right side is slip on and clamped. The left side is swaged on the rear pipe to mate with the header-cat oversize taper. Behind that swaging is a 3 hole clamp and 3 bolts tighten this clamp with the threaded header-cat flange to snug the joint together. There is no gasket. Most "cat-back" aftermarket exhausts connected the same way but what you find on any particular zr-1 could vary widely.
Founding #006
Former Membership Director
NCM member
Grand Sport registry
bhedberg is offline   Reply With Quote
Old 10-22-2017   #3
On the 3 bolt flange are these through bolts and nuts,not studs and nuts? Thank so much for the info.
Old 10-22-2017   #4
Ccmano
It is 3 bolts into a threaded flange. Prep well wth penetrating oil or you might break one off. Just did mine a few days ago.
H
[B]90'ZR-1[/B] #1461 Red/Black
[B]08 C6 Z51[/B] Crystal Red Metallic Sold Vararam Intake, Tune, Sold
[B]05 C6 Z51[/B] Red/Black Sold
[B]90'ZR-1[/B] #1723 Black/Gray Sold but not forgotten
[B]91' Z51 L98[/B] White Vert. My First, you always remember your first. Sold.
Old 10-22-2017   #5
bhedberg
The flange on the cat is threaded. (Saving a thousand words)
Founding #006
NCM member
Old 10-22-2017   #6
That's what I was afraid of,with my luck I hear a snapped bolt in my future.
Old 10-22-2017   #7
Ccmano
Not so bad... worst case you drill the bolt out, rethread to next size, buy a new bolt.
H
Old 10-23-2017   #8
jss06c6
Wasn't a problem on my '91 when I swapped to SW headers and exhaust..
Old 10-24-2017   #9
Racinfan83
When I did mine I just put a standard header collector gasket on it. Just for peace of mind...
[LEFT][SIGPIC][/SIGPIC][/LEFT]
[CENTER][COLOR=Indigo][SIZE=4][I][B] **Now Sold** 1990 ZR-1 #2093, Black on Black..[/B][/I][/SIZE][/COLOR][/CENTER]
Old 10-24-2017   #10
BigJohn
BigJohn's Avatar
Lately I have been dropping a lot of things; last night it was a tractor!
