Old 10-20-2017   #1
Ozruss90
Ozruss90's Avatar
Default Power steering reservoir
Can someone please confirm if the zr1 reservoir is different to std.c4. My 90 model was in a minor accident and according to the repairer, one of the outlet tubes that the hose pushes onto is cracked. He is going to see it can be plastic welded, but if it's not, will have to get a replacement. Question; Are they available new or used?
Thanks.🇦🇺
Ozruss90 is offline   Reply With Quote
Old 10-20-2017   #2
QB93Z
QB93Z's Avatar
Default Re: Power steering reservoir
I do not know if the tank is different for the ZR-1, but I may have a Power Steering Tank (that came from a ZR-1) in the garage. I will look and let you know.
1990 Black ZR-1 - sold
1993 Quasar Blue ZR-1
1994 Competition Yellow ZR-1
1995 Dark Purple ZR-1
Maryland State Coordinator
Old 10-20-2017   #3
WVZR-1
Reservoir needs to be LT5 but from any year. A GM part# 26017982 if you'd like to shop the "down-under" for possibilities.
Old 10-20-2017   #4
I have used ones in stock if you are unsuccessful elsewhere.
http://www.jerrysgaskets.com/reservo...used-90-95-6d/
Old 10-20-2017   #5
Ozruss90
Ozruss90's Avatar
Thanks guys. Even if the repairer is able to repair/weld it, l might chase up a secondhand one anyway. I'll talk to my repairer about it next week. It's comforting to know that l can source one from the USA and have shipped to AUSTRALIA if need be
Cheers
Old 10-23-2017   #6
Ozruss90
Ozruss90's Avatar
Thanks Jerry.
I will take one of those reservoirs of your hands. I'll just work out what other bits and pieces l need from you and place the order. Freight wise, l might as well make it worth while.
