Old 09-26-2017   #1
Pete
Pete's Avatar
Default Closed Decks
WoooHoooh
Closed decks are here.
391ci the easy affordable,fast way.
Sleeves on hand no waiting.
These are very strong thick sleeves you can Turbo or Nitrous these blocks.
Also corrected some proprietary common LT5 issues that our LT5's have.
We can go up to 4.155 on these.
Looking into making some MLS gaskets for the big bore (4.155)
'91 #1635 PoloGreen 350 LT5
11.09 @ 129.27
11.04 @ 128.86
474RWHP 400RWTQ
Old 09-26-2017   #2
Default Re: Closed Decks
Pete,
That's great news!! Just in time for winter projects.
Those sleeves are steel, I assume. And, no milling out the bores either!?
AND, using the stock crank, or is it also offset ground?
Gotta ballpark idea on the turn-key price?
Man! those blocks would really put some lead in the FBI's pencil at the US-41 (CPCC) drag races!! That trophy might as well take up a permanent home with us!
Old 09-26-2017   #3
Wide_One
[QUOTE=Pete;268167]WoooHoooh
391ci/390<----ford as 383 mopar the easy affordable,fast way.-----Make it "396"
Sleeves on hand no waiting.-------------Cool
We can go up to 4.155 on these. --------Yes,
Looking into making some MLS gaskets for the big bore (4.155)<----old school g.m. super duty. Better numbers for bore stroke ratio and for unshrouding the valves, stock mls is 4.15 for wet liners
Congrats!
3.66x4.15 = 396
Wide_One is offline   Reply With Quote
Old 09-26-2017   #4
Jagdpanzer
Jagdpanzer's Avatar
Great work Pete!
Can't wait to see the results of the first motor. No doubt it will be a screamer.
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 09-26-2017   #5
ssrszz4
Where are these blocks coming from
ssrszz4 is offline   Reply With Quote
Old 09-26-2017   #6
They're ur block fitted w the sleeves.
Old 09-26-2017   #7
BTW, does anyone have an explanation for why GM or Lotus went w the open deck design.
Old 09-26-2017   #8
Pete
Pete's Avatar
[QUOTE=Wide_One;268176]
Originally Posted by Pete View Post
WoooHoooh
Congrats!
3.66x4.15 = 396
Anything is possible LOL
How about offset grind crank to 3.75 and make it a 400
Pete
11.09 @ 129.27
11.04 @ 128.86
474RWHP 400RWTQ
Old 09-26-2017   #9
Jagdpanzer
Jagdpanzer's Avatar
I believe it was a fad going around the engine design community at the time. For low rate high end engines like the LT5 it allowed the complete precision finished Nikasil coated aluminum liners, pistons and rings to come as a drop in package from one supplier which in this case was the German company Mahle. Mahle was also supplying many of the other sport car engine builders including Porsche and Ferrari. I am very well aquainted with Mahle from my many years with MTU. All of the high performance marine diesels we produced had pistons from Mahle.
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 09-26-2017   #10
Pete
Pete's Avatar
Great work Pete!
Thanks Phil
The first one i will keep cost down by using stock crank & rods.
Can't wait to test it in my car with my cams and heads.
Can you says 10's
Pete
11.09 @ 129.27
11.04 @ 128.86
474RWHP 400RWTQ
