Old 09-21-2017   #1
Jagdpanzer
Jagdpanzer's Avatar
Default Potential Fuel Pressure Regulator Solution
Looking into potential alternatives to our NLA fuel pressure regulators.
Here are some photos of tansplanting a later style Delphi regulator to the original LT5 regulator body. So far looking very promising. Next step is machining a retainer ring and drilling and threading several screw holes to hold it together. Then test it out. Will keep everyone here posted as to the results.
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 09-21-2017   #2
Default Re: Potential Fuel Pressure Regulator Solution
Wow
Old 09-21-2017   #3
Roadster
Roadster's Avatar
I agree......WOW.....
1974 LS4 454 Vert
1974 L-82 355 Vert.
Old 09-21-2017   #4
Is the stock one just a press fit?
Old 09-21-2017   #5
Jagdpanzer
Jagdpanzer's Avatar
The stock one is an old school design with a separate diaphragm and valve disk assembly under the vacuum dome.
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 09-21-2017   #6
I think you could just zip tie it in.....lol
I have an old one someone sandblasted if you're looking for ones to test things on
Old 09-21-2017   #7
Jagdpanzer
Jagdpanzer's Avatar
Sure, send it over
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 09-21-2017   #8
The L98 was a bolt in top.. maybe a ring with screws to bolt in..
Old 09-21-2017   #9
Regimof
Literally just had this issue. Please keep us informed
Regimof is offline   Reply With Quote
Old 09-26-2017   #10
Jagdpanzer
Jagdpanzer's Avatar
Retainer ring finished and regulator installed on the fuel rails. Now on to the testing phase. Wish me luck.
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
