Old 09-10-2017   #1
5ABI VT
Arrow FS: Fidanza Aluminum flywheel, OEM pressure plate
EDIT** everything is out and for sale.
Will be up for sale shortly just wanted to start a thread if thats ok. Had the setup in for about 2k miles. Believed the clutch to be slipping but didnt even drive it since to figure it out since I planned a twin disc replacement anyways. Car still runs and drives and shifts fine. Will make a video today or tomorrow if I can find time to fire it up and idle with clutch in and out to show how quiet and whine free the setup is. Might be keeping the slave cylinder for my 93 Lt1 car. Bearign was brand new when installed in my car. I purchased an old stock clutch setup and kept the bearing and sold the oem pressure plate that was new etc. have pics and documentation to show the purchase etc from ebay.
Fidanza $225
oem pp was refurbished by Jim Jandik $100
Plus shipping.
Old 09-12-2017   #2
Vette73
Default Re: FS: Low km INA throwout Bearing, Fidanza Aluminum flywheel, OEM pressure plate
Is fidanza flywheel still available?
Sent from my LG-TP260 using ZR-1 Net Registry mobile app
Vette73 is offline   Reply With Quote
Old 09-12-2017   #3
5ABI VT
It is still available. I hope to have it out very soon I haven't had any time at all to work on the car but it shouldn't take more than a few hours when I get started. I should the prices were plus shipping .. will add it to the op.
Old 06-11-2018   #4
5ABI VT
Wanted to bump this instead of making a new thread. Everything is for sale and ready to go.
Some pics right before install and after removal. The flywheel surface was covered in fluid I believe from the Slave. The disc that was removed had literally 0 wear as I only had about 1500-2k km on the setup. Pulled it all due to a little slippage due to oil contamination and decided to just go twin disc and hydraulic t.o bearing conversion from Jerry/Ram.
Whole setup before install
LT5 pressure plate
Fidanza/ spec light flywheel
Flywheel after removal
Old 06-14-2018   #5
scottskill
Default Re: FS: Fidanza Aluminum flywheel, OEM pressure plate
What's the condition of the disk?
Sent from my SM-G955U using ZR-1 Net Registry mobile app
scottskill is offline   Reply With Quote
Old 06-14-2018   #6
5ABI VT
Here’s a pic of the disk. It’s pretty much new there was signs of some oil/brake fluid which was causing the slight slippage. Not sure if it can be brake cleaned and used but happy to throw it in with either the Pp, flywheel or both. It’s a dual friction organic on one side and metallic on the other and sprung center.
Old 06-15-2018   #7
scottskill
Sir, Who manufactured the clutch disk and is there a part #
Old 06-16-2018   #8
5ABI VT
The disc is not an oem disk. I believe it’s a Spec brand.
Old 06-30-2018   #9
scottskill
Sir, still available?
Old 06-30-2018   #10
5ABI VT
Yes still available !
