Old 08-17-2017   #1
ssrszz4
Default Headlight
I took my left headlight off to investigate why it only opened half way and discovered the rolls in the gear had turned into a sand like substance. I already had a new gear and rollers so replaced them. I'm wondering if it was a chemical reaction between the rollers and the lube they used!
ssrszz4 is offline   Reply With Quote
Old 08-17-2017   #2
BigJohn
BigJohn's Avatar
Default Re: Headlight
Was it? Things sometimes just ware out!
Old 08-17-2017   #3
ssrszz4
They where more diisinagrated then work out i think
Old 08-17-2017   #4
very common, there are those that have and those that will.....
Steve
1990 Steel Blue/Black #2355
1990 Red/Red #1473
1991 Quasar /Black #118 Sold
1993 Yellow/White #179 Sold
Old 08-17-2017   #5
ssrszz4
I see! I'm was not the gear at all it was fine.
Old 08-18-2017   #6
Bruce
The ones on my 91 did the same, I replaced them both at the same time. Interestingly my Lotus Esprit turbo SE headlights started doing the same, and when I looked at the motors, they are the same as the Corvette ones, so I just ordered 2 sets of dowels and replaced both on the Lotus.
Also my Lotus has the same Centre mounted high stoplight identical to the ZR1. I guess since its an 89 model it was in development in the UK the same time as the ZR1 and Lotus must have been on a parts bin robbing session of the GM bins!
Bruce is offline   Reply With Quote
Old 08-18-2017   #7
G8nightman
G8nightman's Avatar
Another ZR-1/Lotus guy same as me. I have a S4 and did the same as you headlight motors are the same as are a few other parts as well.
90 Chevy ZR1 LPE #2315 'SOLD'
90 Chevy ZR1 LPE #2774 'SOLD'
91 Chevy ZR1 #1512
91 Chevy ZR1 #951
95 Chevy ZR1 #338 'SOLD'
91 BMW 850i
94 BMW 850csi
95 BMW 850csi
94 Lotus Esprit S4
07 Benz CLS550
06 BMW M5 "SOLD"
G8nightman is offline   Reply With Quote
