Old 08-04-2017   #1
5ABI VT
Question Best option for fuel pressure regulator replacement ?
Don't think there is anything wrong with mine but since I've replaced most of the fuel system components I would really prefer to change it out with a quality replacement.
A few solutions I think are :
1. Aftermarket replacement which as many know are available from some parts stores.
2. Have custom fuel rails made that accept an fittings allowing an aftermarket replacement.
3. Modify the oem rails to accept an fittings also allowing an aftermarket regulator.
The goal of course is just to have a quality replacement. Something adjustable doesn't hurt as it allows optimal fuel pressure settings etc.
Any thoughts ?
Old 08-04-2017   #2
secondchance
Default Re: Best option for fuel pressure regulator replacement ?
Option 1: I could have sworn that rockauto had non-oem alternative but I don't see them anymore on their website.
Option 2: anything is possible but most likely very costly.
Option 3: probably doable but trick is making it look attractive.
Old 08-05-2017   #3
Top Toy
Top Toy's Avatar
Lingenfelter used to sell adjustable regulators for our cars. Probably discontinued but can't hurt to check. If you zoom in on the attached photo, 1501933805631.jpg you can see mine.
Sent from my XT1254 using ZR-1 Net Registry mobile app
'95 ZR-1, aqua/gray, #167
368 LPE/Haibeck, Web cams, Stainless Works headers, B&B Fusion exhaust, 18" Fikse wheels, Alcon brakes, lowered. 491 SAE RWHP.
Top Toy is offline   Reply With Quote
Old 08-05-2017   #4
I always check Jerry's Gaskets site first.
90 #1202
Sans secondaries
SW headers, X-pipe, MF muffs
Old 08-05-2017   #5
secondchance
He is out of stock also.
Old 08-06-2017   #6
mgbrv8
Originally Posted by Top Toy View Post
Lingenfelter used to sell adjustable regulators for our cars. Probably discontinued but can't hurt to check. If you zoom in on the attached photo, Attachment 6411 you can see mine.
Just out of curiosity does anyone have any close up pictures of one of their regulators??
Old 08-06-2017   #7
RussMcB
Do the stock regulators go bad some times?
Old 08-06-2017   #8
Top Toy
Top Toy's Avatar
Old 08-06-2017   #9
secondchance
Yes. Mine went bad around 130,000 miles. Diaphragm ruptured inside and fuel was getting sucked in through the vacuum line into the plenum above #7 cylinder.
Old 08-06-2017   #10
mgbrv8
Thank you Sir
Dave
