Old 07-10-2017   #1
Default Hard Brake lines
Anyone know if the steel brake lines are the same as a standard C4? Not the lines to the caliper but the ones from the ABS pump forward....
Old 07-10-2017   #2
Default Re: Hard Brake lines
from the ABS to the Caliper? I would think yes. From Master to ABS, probably not
Old 08-01-2017   #3
Talked to Classic tube they think the Z has completely different lines, and they don't have the pattern
Old 08-01-2017   #4
some of them are (At the master)
otherwise the frames are the SAME? as the rest of the lines should be
Old 08-01-2017   #5
Hmmmm.....I have corrosion on the ones coming off the ABS
