07-10-2017 | #1 |
Stalling issue fixed...I hope...
I hesitated to post this, cuz I'm a little embarrassed. I forgot just a leeeetle step in setting the idle air screw/IAC procedure and it caused me some confusion, frustration, and ultimately caused me to doubt my abilities to walk and chew gum simultaneously! But, then I figured mebby I can help someone else from having the same issues. Here's my story and I'm sticking toit!
Ami's (race-prepped) 91 ZR-1's RPM always seemed to sag and then stall immediately after firing up after the car was sitting over night, i.e., COLD. If one could catch the sag with a blip of the throttle, the stall was avoided and all was well. But, that was the first indication of things to come. Then things began to develop: occasionally it would stall after coming to a stop. And, when the summer temps and humidity rose, it would stall every time when coming to a stop - less than 100% only if the AC was not turned on. The scanner (best tool I ever bought!) told of some issues: the RIGHT side O2 was sluggish, and the average voltage was on the low side, compared to the LEFT O2. (I replaced that first as the O2s need to be working properly before attempting to do anything else with the idle.) the TPS voltage was a bit "off". the IAC counts were mid 80s to 90s. (should be way, way lower. Yikes!!) The "desired" idle setting was 850 RPM, but actual was 1100. That didn't alarm me, cuz I suspected that was due to whatever might be caused by those other issues. And, it was. Attempting to lower the IAC steps, by adjusting the TPS idle air screw - , I musta forgotten the instruction regarding setting the idle air screw: cycle the ignition OFF for 10 sec or so before re-starting the motor and reading the IAC counts again. Cycling the ignition between changes in the TPS, and especially the TPS idle air set screw is critical. Otherwise, the IAC counts may change some or not at all if one tries to adjust the idle air screw with the motor running. (Hey! I'll blame it on decades of carburetor experience w/ idle air screws! At one point I was turning the screw clockwise [to open the primary throttle plate] when idle RPM started running away yet the IAC counts remained unchanged!) Anyway, cudos to Marc Haibeck, and later reiterated by Dominic for reminding me about cycling the ignition OFF/wait/ON between adjustments: a day and night difference! ______________ I'll save anyone who has done this the eye strain of setting the IAC beyond this point. But, for those interested in setting their IAC/TPS, and have either a scanner or a computer program (Tunerpro or the like), this is what worked best for me... For those unfamiliar, idle air screw is intended to assure the motor will start and idle in a fashion until the ECM can take over idle chores. Screwing the idle air clockwise opens the throttle plate letting in more air. The Idle Air Control (IAC) is controlled by the ECM to further regulate the air flow by pulsing (or stepping) the IAC motor: the greater number of "steps", the more air is allowed past the throttle plate. With only the motor running at operating temp, i.e., no lights, fans, AC, etc., the IAC steps should be low, e.g., 5 to 10 depending on the motor's tune and other factors. The Throttle Position Switch (TPS) is responsible for telling the ECM the position of the throttle plate (opening). Optimally, it should be 0.54 volts when at normal idle. By loosening the two screw at the front of the TPS just enough, the TPS can be rotated to increase or decrease the voltage to achieve the optimum setting of 0.54 volts. (BTW, any changes to the idle air screw will directly affect the TPS voltage. So, changes to the TPS voltage should only be done after the idle air screw has been adjusted - NOT the other way around!) NOT cycling the ignition between settings (idle air screw in particular and TPS voltage) was an exercise in frustration. Once that was resolved, things went off "easy-pleazy": Note: The more air let in via the idle air screw, the fewer IAC "steps" will be called for by the ECM. After backing off the lock nut, turning the idle air screw clockwise will ultimately LOWER the IAC steps, and visa-versa.
So far, so good. Actual idle RPM matches the "desired" set RPM value (more or less, allowing for the loping cam idle) No more sagging and stalling on first startup of the day No more stalling when coming to a stop or idling in traffic, with or w/o the AC and/or the lights running. Happy wife...happy life!
Good carz, good food, good friendz = the best of timez! 90 #1202 "FBI" top end ported & relieved Cam timing by "Pete the Greek" Sans secondaries Chip & dyno tuning by Haibeck Automotive SW headers, X-pipe, MF muffs Former Secretary, ZR-1 Net Registry Last edited by Paul Workman; 07-11-2017 at 10:51 AM. |
07-10-2017 | #2 |
Re: Stalling issue fixed...I hope...
Great write-up, as I will add this and Dominic's write-up to help get me get the engine started when all of my work is complete....
07-10-2017 | #3 |
Glad you got it sorted out.
07-10-2017 | #4 |
07-10-2017 | #5 | |
There are several software options for laptops and even smart phones with Bluetooth plug-in to the ALDL port.
07-10-2017 | #6 |
Another gem, thanks Paul.
H
