![]() Join Date: Jul 2015
Halo everybody I'm going to refresh my LT5 engine so I replaced my coils with Msd
And I changed my fuel injector with I replaced the injector with 21 lbs But the table it shows me 21 lbs below 9.7 compression and the LT5 eng is 11.1 compression ratio. Which one is better for The LT5 is there any suggestions or recommended to go with ??? Sent from my iPhone using ZR-1 Net Registry Last edited by STATION; 04-27-2020 at 08:16 PM. |
![]() Join Date: Aug 2006
My 378 mini stroker is at 12.5 and Accel 21 pounders are perfectly fine.
#3 | |
I s/up my engine with accel 21 and it run fun . The number on the duno 350 hp ![]() And there is no problem. But if i go with the table and install accel 30 lbs there's any problem.. Did anyone install 30 lbs Sent from my iPhone using ZR-1 Net Registry |
![]() Join Date: Nov 2011
I'm not the expert here, but don't forget you have two injectors per cylinder.
![]() Join Date: Nov 2007
8 years now on Accel 150821s. Runs perfectly from idle to 7600 rpm. Compression now 11.5:1 with full porting. Dyno'ed 432 hp at the wheels on pump gas. Stock idle = real SLEEPER!
#6 | |
Yes your right I forget that. That means 21 *2 = 42 lbs Thank you my friend [emoji106] Sent from my iPhone using ZR-1 Net Registry |
#7 | |
I'm just Confused [emoji23][emoji106] Sent from my iPhone using ZR-1 Net Registry |
![]() Join Date: Apr 2017
Accel used to be a quality product. I read that their injectors are now made in China (??). Does it say on the packaging? If that matters to anyone.
I used to be a die hard MSD proponent myself. Used them many times since my first hot rod build in 1980. But now I read that they moved their coil & ignition production to China. Over the years I have had loads of problems with parts made or rebuilt in China. I do everything I can do to keep away from them. Does anyone know who makes coils for our cars that are made in USA? |
#9 |
![]() ![]() Join Date: Aug 2005
Air/Fuel ratio looks a little rich....
#10 |
![]() Join Date: Jul 2012
I replaced my coils with AC Delco Professional Grade. Gold plated (corrosion proof) terminals. Don't know how the rest of the specs compare but they seem to work well.
Sent from my XT1254 using ZR-1 Net Registry mobile app
'95 ZR-1, aqua/gray, #167 368 LPE/Haibeck, Web cams, Stainless Works headers, B&B Fusion exhaust, 18" Fikse wheels, Alcon brakes, lowered. 491 SAE RWHP. |
