![]() Join Date: Aug 2005
All,
I need to source a set of phenolic plenum spacers. Wish I'd bought Lee's last year for a good price. Anyway, I'm hoping to use these to correct a slight misalignment I'm having with the ports on my personal engine. Would rather grind on the phenolic to make a smooth transition between plenum & IH. Last edited by tpepmeie; 06-26-2017 at 12:22 PM. |
![]() ![]() Join Date: Jul 2005
Todd,
I've been running a set for years - I purchased 1/4" phenolic sheet from NORVA Plastics when I lived close to them (they sell excess job material on eBay), and made my own using the gasket as a template. The material is very easy to work with and cut/shape/sand as needed. They are currently selling 1/4" sheets on eBay (G10). Good Luck! Regards, Mark
Mark Horner President, ZR-1 Net Registry 91 ZR-1 #2016 95 ZR-1 #21 DRM-600, LPE 385 |
#3 | |
![]() Join Date: Jun 2013
![]() Join Date: Apr 2017
Not to Hijack a thread but what is the advantage or disadvantage to these spacers. I've never really got a straight answer from anyone. I have a set on my car that a previous owner had put on and I thought about removing them when I do my first plenum pull if they are not helping the performance of the car.
Steve,
_______________________ 1990 Bright Red/Black #946 B and B X-Pipe Stainless Works Long Tube Headers Cat delete 49th Street Rockers Haibeck Chip and Tune |
![]() Join Date: Dec 2003
Principal Advantage: Thermal insulator for plenum, to impede heat soak from the engine
Other Advantage: Marginal increase in air circulation under plenum, aids in cooling of plenum & DIS Module. Disadvantage: 1/4" spacers frequently result in intake contact with underside of hood. Disadvantage: Requires some bending of vacuum line to PCV top connector. Disadvantage: requires 2 sets of plenum gaskets. & longer bolts
I know Todd needs them for another purpose, but the spacers introduce one more place for a vacuum leak.
#7 | |
^^^ what he said. I'm not doing this for any performance impact, and I doubt the claimed benefits of plenum insulation are even measureable! I just need the spacers to improve the transition interface between the housings and plenum. What happens, in my case, is a slight decking of the block, combined with skim cut on the cyl head deck, and a thinner MLS gasket = the heads sit fractionally lower. The plenum ports no longer line up perfectly with the housings, so I need to fix that. We're talking millimeters here. One added consequence, the extra 1/4" or so should move the natural tuned length of the intake slightly lower (perhaps 100 rpm). Peak torque on Build 1 was 5800 rpm, which is more or less where the factory HP peak was, and where the stock runner length is tuned. |
Todd, I have a used set of 1/4" on an engine I acquired last year.
#9 |
![]() Join Date: May 2010
Todd,
If you don't get the set from Jerry, I have a new set that I bought from Lee earlier this year. It sounds like you need it more than me. Aloha, Craig
Craig "ZR-1 NO KA 'OI" "ZR-1 ICHIBAN" 1995 #228 Black/Black with Dunn Heads ZR-1 owner since September 2003 ZR-1 Net Registry Founding Member #0074 NCM Lifetime Member #2048 ![]() |
