Old 06-13-2017   #1
TucsonZR1
Default DERM
Is there anyone rebuilding the 1990 DERMS, tried the gut in Texas and his phone is disconnected.
Old 06-13-2017   #2
Default Re: DERM
Bummer.. I know my 1990 got swapped to the 1991 stuff some point before I bought it
Old 06-14-2017   #3
Default Re: DERM
Not that I am aware of anymore. There was a vendor on Ebay for a while but I haven't seen them advertise for years.
Your 90 DERM is a one year only DERM. About the only good news is they are NOT ZR-1 specific. A few units on EBay are available in the HI $300 to $400 range. Good luck. GC
Old 06-15-2017   #4
TucsonZR1
Default Re: DERM
Thanks for the info, is it very involved changing it to the 91 system?
Old 06-15-2017   #5
Default Re: DERM
Yes I believe it is. I think all the sensors and harness need to be replaced along with the steering wheel and airbag. Like I said, my car was changed prior to me getting it
Old 06-16-2017   #6
Phillip_G
Default Re: DERM
I just used Airbag Systems Inc (2 weeks ago). I think his name is Chris and he's located in Allen, TX. He just helped me sort out my 1990 DERM and get my system back functional and INFL REST light off. He did a nice job and was very helpful but I think it turns out that my problem wasn't the DERM but that I had simply bent the grounding clip in the connector to the steering column so when I plugged the connector together it was still grounded thus causing the fault. Got it back together correctly, cleared the codes, and it's fine now.
Phillip_G is offline   Reply With Quote
