05-23-2017 | #1 |
Starting issue?
Yesterday morning after a stop for breakfast, my car wouldn't start. It had power and acted like the safety switch on the clutch was not working. After multiple key cycles and locking and unlocking the doors it still would not start. We were able to get a ride home and then went back to try again. I used the spare set of keys and the car fired right up. Is it possible that I have a bad VATS key? I was also able to start the car with the primary set of keys.
Any help or suggestions would be helpful. Thanks, Jon P.S. I haven't tried to start the car since I brought it home yesterday. |
05-23-2017 | #2 |
Re: Starting issue?
Crank it and drive it around close to home until it is good and hot. Turn it off. See if it cranks back up. If no, let cool and try with same set of keys. If it cranks cold, remove intake and fix starter solenoid. At least that's what I'm doing now.
1990 ZR1, 1987 Mustang GT (since new), 1973 DeTomaso Pantera, 1987 928S4 Passed on: 1984 930S (gray market), 1988 Mustang Coupe Trooper car(drag) |
05-23-2017 | #3 | |
Re: Starting issue?
GOLDCYLON - 91 ZR-1 #2014 GOLDCYLON - 90 ZR-1 #2794, 4L60e (Formerly Schrade's) GOLDCYLON - 11 CTS-V Arizona State Director 91 WHITE/BLACK #2014. 380 P&P&PCed,Ported Heads, Jeal Long tubes, Corsa Exhaust/FIKSE FM-5s /LED TLs, LED Headlights, Front Wilwood 6 piston narrowlite calipers and rear Wilwood caliper street shop mod,CNCed Coolant Pipes,TPI Cvr,Filter cover,Stainless Bolts, DRM/DOM PROM /ZFDOC mod build #102,DRLs,BMAD with stainless Debris Screen,Coplan Air Blaster, Pioneer APP Radio 4,Brey-Krause HB,Sub Bar,Fire extinguisher seat mount,DRM Coilovers,LEDs everywhere,Compass mirror (orange),V1 DIC hidden display, Homelink sun visor, Carbon Fiber top x3 and APSIS Carbon Fiber interior, APSIS CF Steering Wheel/NAPA Leather, Banski trailing arms, Guldstrand front suspension,urethane bushings from Prothane (total suspension) ZFDoc drive shaft safety loop, raptor shift light (orange),AO engineering louver front plate, Console seat cushion, 96CE seats with black custom Sheepskins, ss billet catch can,Viper remote entry/alarm,Cragar Rear Louvers,LED side louver lights, Dewitts Radiator with SPAL fans and a Woods 160 T-Stat 90 RED/BLACK #2794. 4L60e Automatic Stage V by RPM Transmission, TCI Dedicated TCM, OBX Stainless Headers, Corsa Exhaust, SAN Secondaries and Haibeck PROM, Exotic Muscle Coil overs, LED Interior Lights, LED Tail Lights, LED Headlights, 94 Sport seats with black custom Sheepskins , Cragar rear louvers, GS Front calipers, Banski Trailing arms, APSIS Carbon Fiber steering wheel, Front and Rear Baer Eradispeeds, DRLs, Guldstrand front suspension,urethane bushings from Prothane (total suspension), Dewitt's Raditor with Dual SPAL fans and a Haibeck 170 T-Stat 11 RED/GREY CTS-V Last edited by GOLDCYLON; 05-23-2017 at 05:37 PM. |
05-23-2017 | #4 | |
Re: Starting issue?
05-24-2017 | #5 |
Re: Starting issue?
Most likely you didn't keep the clutch in all the way before turning the ignition key. The VAT kicked in and disabled the starter. Wait 10-15 before properly starting your Z again. I got burned many times before I read about this is the Forum...
05-24-2017 | #6 |
Re: Starting issue?
when mine did this it was the clutch switch, jumpered that out and it worked ever since
05-24-2017 | #7 | |
Re: Starting issue?
Thanks, John
1992 #043, Aqua/Gray 40k miles |
05-31-2017 | #8 |
Re: Starting issue?
Here is Marc Haibeck's article on starting issues, every new Z owner should read!
FYI, you can measure the resistance across the "pill" in your ignition key and compare it to the chart (below). From that, and your ignition key, a locksmith will be able to cut you a new key with the proper resistor chip.
Good carz, good food, good friendz = the best of timez! 90 #1202 "FBI" top end ported & relieved Cam timing by "Pete the Greek" Sans secondaries Chip & dyno tuning by Haibeck Automotive SW headers, X-pipe, MF muffs Former Secretary, ZR-1 Net Registry Last edited by Paul Workman; 05-31-2017 at 09:41 AM. |
06-01-2017 | #9 |
Re: Starting issue?
Exact same issue happened to me about a month ago - starter would not start from time to time and after it sat for a few hours it started up! Turned out under the plenum an oil gasket went bad sending oil into the starter which is located by the firewall. After to oil dried up it would start but ended up replacing the starter and gasket to fix the problem. Hope that helps...
06-01-2017 | #10 |
Re: Starting issue?
Speaking of "starting" issues, has anyone encountered the situation where the starter operates but the Bendix sounds as if there is a missing flywheel tooth?
It will happen once, maybe twice in succession. Let sit for a few moments and then it engages. I have also rocked the car a couple of times and the flywheel is engaged. Comments?
