View Poll Results: EVAP connector....did it have a plastic tie on the topside?
Yes 2 40.00%
No 3 60.00%
Voters: 5. You may not vote on this poll
Old 05-17-2017   #1
Roadster
Roadster's Avatar
Default Plenum Pull Poll...
For those who have done a plenum pull and can remember if the EVAP connector that connects the plastic lines to the solenoid and to the plenum and the canister line, did that connector have a plastic tie around the topside of the connector as shown?
Most likely it would be a black tie and not the different color as shown in the pic.
Although it has been mentioned that the MM did not use ties, the few used EVAP lines and connectors that I have seen and the NOS unit recently viewed do have the plastic tie on the connector.
Thanks for your participation.....
1974 LS4 454 Vert
1974 L-82 355 Vert.
Old 05-17-2017   #2
Jagdpanzer
Jagdpanzer's Avatar
Default Re: Plenum Pull Poll...
Yes, mine had one
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 05-17-2017   #3
Young1
Young1's Avatar
Imho put ties everywhere possible. Prevent leaks. Keep the vacuum where it belongs.
Old 05-17-2017   #4
902066
I have pulled my plenum way to often recently, but I don't believe it ever had a tie rap in that location.
902066 is offline   Reply With Quote
Old 05-17-2017   #5
Roadster
Roadster's Avatar
Yes, mine had one
Thanks Phil...
I understand what you are saying, but that is for another discussion. As there may be pros & cons to that thought...
I am just trying to determine those who have done a plenum pull and what was attached or not attached to the EVAP connector. And it is possible that someone may have completed a plenum pull in the past, (such as a PO) and they may have or may not have added or undid the plastic tie if indeed there was even one there to begin with...
If you feel that the plastic tie was not there, please answer in the poll....thx...
1974 LS4 454 Vert
1974 L-82 355 Vert.
Old 05-18-2017   #6
Roadster
Roadster's Avatar
Just received an NOS EVAP connector assembly today. As you will notice in the pics, there is a black plastic tie around the connector. And the plastic "lines" fit in the connector very tight. There is even one spot where the "tube" seems to be dented, maybe from when the installer was inserting the tube into the connector...JMO
So IMO this seems to confirm that there was a plastic tie installed from MM when the engine was assembled. Again, JMO.....FWIW...
1974 LS4 454 Vert
1974 L-82 355 Vert.
Old 06-07-2017   #7
Jim Stanley
Where did you purchase the NOS EVAP connector assembly? Thanks!
Sent from my iPad using ZR-1 Net Registry
Jim Stanley is offline   Reply With Quote
Old 06-07-2017   #8
Roadster
Roadster's Avatar
It was listed on ebay....
1974 LS4 454 Vert
1974 L-82 355 Vert.
Old 06-07-2017   #9
Jim Stanley
Amazing, thanks
Old 06-07-2017   #10
Roadster
Roadster's Avatar
Amazing, thanks
Jim, from what I remember, this seller did not have many ZR-1 parts for sale.
I think 2 or 3 at the most. I got lucky, as it was a good find...
1974 LS4 454 Vert
1974 L-82 355 Vert.
