Old 05-14-2017   #1
1991KOTH
Default Burping an air filled coolant system: The better way
Hey yall, just figured out a way to burp the coolant system of air that will work 100% of the time. I tried Haibecks method, but with little success.
Things youll need:
Rubber hose to connect to reservoir
Something to collect coolant with
A big Funnel
Coolant to refill your car
Turkey baster
Now, the first thing to do is siphon out the coolant until it no longer reaches the lower tube. The next step is to disconnect the lower tube and place it in something that will collect the coolant that drains out. Next, place the new piece of rubber tubing onto where the old lower tube was on the reservoir. Now place your funnel onto the reservoir to get ready to fill the system. Also place the new hose in the funnel. Now fill the funnel almost full. Start the car. Coolant should start to drain out of the funnel. Keep refilling it. Big bubbles should start to arise. Keep doing this until the system no longer accepts anymore coolant. Congrats! You have now burped the system with ease! Now reconnect everything the way it was.
Note: You may have to fill the coolant further after a short drive. I did.
1991KOTH is offline   Reply With Quote
Old 05-14-2017   #2
Roadster
Roadster's Avatar
Default Re: Burping a air filled coolant system: The better way
Sounds like a good idea, I will try this when I get everything back together. Thanks for posting.....
1974 LS4 454 Vert
Old 05-15-2017   #3
ssrszz4
Wish you took pics kind of confused.
ssrszz4 is offline   Reply With Quote
Old 05-15-2017   #4
1991KOTH
Yeah, I forgot to take them as I was doinhg it.
Old 05-15-2017   #5
1991KOTH
Edited the post to possibly help out a little bit more
Old 05-15-2017   #6
ssrszz4
Default Re: Burping an air filled coolant system: The better way
It sure sounds like you have found the solution to this problem.
Old 05-15-2017   #7
George45
Ok. I need pictures. Im lost.
Sent from my SM-T817V using ZR-1 Net Registry mobile app
George45 is offline   Reply With Quote
Old 05-15-2017   #8
1991KOTH
Will get pics soon
Old 05-15-2017   #9
Roadster
Roadster's Avatar
I think if you reread the post a few times over, and visualize each individual step, you will understand it better.
It's actually very simple. The hardest part IMO is removing the lower hose on the reservoir in one piece. Sometimes it is really stuck on there...JMO
A side note....when you look into the reservoir (near the windshield) and undo the radiator cap, you will see two "tubes", an upper and lower tube that has hoses attached to them on the outside of the reservoir. I am also sure that is what he is referring too.
Sent from my SM-G935P using ZR-1 Net Registry mobile app
1974 LS4 454 Vert
Old 05-15-2017   #10
1991KOTH
That is exactly what in referring to
